Re: Show us your Door Thread
Hey mikku
Am looking for tempered glass as we speak no luck yet. But will persist
Thanks Rbhumbert, I know what you mean when baking bread even harder when you have no handles, but I have rectified that and door now works a treat. I also have a steel door and follow your method above.Originally posted by Rbhumbert View PostLiteceeper, Very nice door and workmanship. My first door was about the same thickness (amount of insulation) but I found it unwieldy when loading multiple loaves of bread. Now if I want to hold extra heat overnight, I use both my new door (the steel one with wheels) and my old door together, then just switch to the single steel door during the bake. I brewed my own beer for over ten years, and I find for me, half the fun is improving the equipment. It's boring watching an electric train set go around the track once it is set up.3 Photos
Has anyone ever tried to use the glass from an oven door, or multiple glass from a commercially produced gas or electric oven to make a door for a WFO?
Am wondering if it is tempered making it impossible to cut after the tempering process. Would be really nice to have a full view door for baking times where the view is not distorted.
What did the old ovens in Europe use for doors in bygone days?
Sure is amazing to see the variations of doors members have fabricated to seal their ovens...all real works of art and the result of a lot of thinking! Gotta say "Wow" each time I see the masterpieces!!!!!!!!!!!
Wow, coming back to the tread after a few days... I see some great workmanship and ideas going on.
Cheers
Steve
Some more build photos.
Box spot welded 1.2mm stainless steel, aluminium front plate 4mm, timber panels screwed from back insulated with red fibre washers.
Insulation calsil left over bits & perlite cement.4 Photos
Nice idea with the rollers Rbhumbert, my door weighs in at 15kg (33lbs) so I might try incorporate whilst I carry out some mods.Originally posted by Rbhumbert View PostThanks, The steel I used for the door is a little heavy duty, but it was what I found laying around. The plan all along was to have the rollers, so weight was not to big of a concern. The door is insulated with ceramic board and it does a decent job of holding in the heat.
Here's my door based heavily on Greenmans design.
Insulated with 50mm calsil board and 50mm perlite render.
I have wooden handles to attach to the brass hex stand-offs but when fitted the door is too deep to angle through front arch without handles jamming, so I need to cut down the hex stand-offs to allow door to clear front arch whilst on an angle.5 Photos
I don't do jealous but I do admire the workmanship and the resulting granite arch. Gives some of us something to aspire to. Very special.
Very nice door indeed and the rollers make moving it possible.
Looking at the photos, it seems like you have some pretty heavy duty steel plate you used for fabrication, what is it 1/4" for the outside and a little thinner for the inner surface?
Did you sandwich any insulation between the surfaces?
Did you plan for rollers right from the beginning? Or after finding out how heavy the door actually is?
Yes, the rollers rotate. I placed them even with the bottom of the door so that when the door pivots forward they make contact with the hearth, the bottom edge of the door lifts free and the door can just be laid flat where it is, or it can be pulled away from the oven door. Don't look to closely at the welding, not my strong suit.Originally posted by TropicalCoasting View Postdo the rollers roll or just give a round smooth surface to slide on?
Close up photo from underneath would be great.
I saw a hinge down door in a video of a commercial oven which I thought was great, but I knew I not only wanted the door to lay down, but also be easily removable for cooking pizza, removing ash etc.3 Photos
