I do not know how many people have done this, but I am making my structural slab indoors for later transport to its final resting place when the weather cooperates.
Made a metal framework from 75x75x6mm angle, used a wooden framework and plywood below, and additional forms on the perimeter to make a slab--total thickness 240mm (9 7/16). It also has a blockout for the under hearth insulation as well as thickness of firebrick floor. Slab: 75mm, 100mm insul, 65mm firebrick. Actually poured the slab: DIY mixture. The concrete company delivery price was unbelievable. I was able to get their chart and calculated batch quantities to mix .25m3 concrete in 8 small batches from bulk materials. From their chart what I am getting is an almost 5000psi mixture. They call it JIS3308.
All went well with the mix, but now I have a block of concrete weighing around 580 kg sitting on the floor of my garage!
In a different thread, I mentioned attempting to source things locally but having trouble. I found fiberblanket (ceramic fiber) and the board (2" thickness) but am blown away by its price. Also there are minimum order or box quantities--I would only need 3 pcs- 2'x3'x2" thick but they only want to sell 4. Each piece costs around $135! That makes hearth insulation more expensive than everything I have done so far! Today, I purchased vermiculite & perlite from a local agriculture center. The pericrete/vermiculite insulation will only run about $39 total for the area of the hearth/landing @ 100 mm thickness.
On a different thread, community members said that you should not imbed the insulation in the slab because it might create a bathtub effect. Would there be anything wrong with drilling a hole in the center of the slab beneath the insulation to act as a drain (if) any water actually migrated there?
A few more questions, then I'll begin this thread.
-Is there any advantage to the ceramic fiber over pericrete besides higher insulation value for less thickness?
-Can anyone give an exact number for compressive strength of ceramic fiber board? For pericrete 5:1:1 mix?
Finally, I have browsed this forum and it will take months to begin to absorb all the information available. It is mind boggling to see all the talent and creative work that is displayed. Thank you Forno Bravo for making this site possible.
