new build in Brisbane - Vibrok Caminetti
    • 5260
    #91
    Re: new build in Brisbane - Vibrok Caminetti
    Here's a pic of a serious top down burn you might find interesting. It is at Jack Daniel's distillery in Lynchburg TN, US It is how they make their charcoal for filtering their whiskey.
    • applor
      • Oct 2013
      • 210
      #92
      Wow that's an impressive burn for sure!
      On a side note, my helpers dropped off some wood today.
      All seasoned of various types but look to be too big so I must go and buy an axe. Any recommendations?
      • Greenman
        • Feb 2013
        • 1123
        #93
        A 5 lb Plumb or Kelly and a garage sale or market is the place to find one. Buying a new one from the big green shed is expensive and the axes are not a patch on the old ones. $25 should get you set. No problem if it has shoulders like Dean Lukin if you are just splitting.
        Cheers ......... Steve
        • Liteceeper
          • Jul 2013
          • 90
          #94
          Hi Applor
          What a co-incident I got delivered today a Fiskar X27 splitting axe, a bit pricey but excellent at what it does. Split a couple of tubs of river red gum for pizza tomorrow in 5 minutes flat. Doesn't jamb in logs as it has some super dooper coating. Online for about $115 and Big green shed for $139.
          Liteceeper
          My Build - http://www.fornobravo.com/forum/f51/...ide-19729.html
          My Door - http://www.fornobravo.com/forum/9/sh...tml#post170496
          "Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
          • applor
            • Oct 2013
            • 210
            #95
            Yeah looks like a top axe but definitely pricey.
            I don't have a problem spending $139 on an axe but I ask whether or not it's worth that extra money over say a $20 or $60 axe...
            Do I need a splitter and a hatchet?
            • Greenman
              • Feb 2013
              • 1123
              #96
              No. An axe will do the job.
              • stonecutter
                • Jun 2007
                • 2003
                #97
                If you want to buy one that will last the rest of your life, I recommend a Gransfors Bruk splitting axe.....Gr?nsfors Large Splitting Axe | Gr?nsfors Bruk
                I've had mine for about 9 years now, and it is a high quality tool. We have owned many axes, and mauls, this one has out performed them all. The first week I had it, I split a trailer load of ash ( it ended up being about 2 cords) and I never used my log-splitter. Ash is fairly clear though, and I don't recommend this axe for knotty wood...the splitting maul or hydraulic splitter is better for than. Gr?nsfors Splitting Maul | Gr?nsfors Bruk
                Great tools develop character as they age too. It's more spendy than the cheapies, but if you get one of these you won't be sorry that's for sure.
                Old World Stone & Garden
                John Ruskin
                  • 2848
                  #98
                  G'day
                  Yes this Fiskar axes are a serious piece of kit. I've used one to thin out re growth size stuff on a block before a house application ( no chainsaw noise so the neighbors don't cotton on)
                  They are a seriously sharp and well balanced axe. I was really surprised. But how are they going to age. That super sharp edge is going to need sharpening sometime ... Will it take a new edge. That super coating, its got to wear over time. As for the handle .. How knows how to replace that.
                  Aussie hardwood is tough .. Its full of iron.. It will tell over time.
                  I've just got a lite 3/4 axe a cheapy. I keep it sharp, carefully with a fine sanding disk on the angle grinder when it needs it. I always rub off the sap with some wet and dry and Kero and store it inside. Never do the leave in in the log in the wheather thing.
                  I would love to get an old axe head and refurb .. But in brisbane all the old tools at the markets are blackened up and polished up and are highly priced... One day, I find a keeper...
                  • Liteceeper
                    • Jul 2013
                    • 90
                    #99
                    Hi Applor
                    I have a range of axes, probably overkill, cannot help collecting things (shiny kit syndrome) the large axe tends to jamb in red gum, the small one is good for kindling and the wedge is used for the real knotty snotty wavey grained red gum which occasionally gets past selection process at wood lot.
                    Will report on fiskar as I get to use it, but a 25 year warranty should see the plastic handle (Carbon fibre) not an issue.
                    Liteceeper
                      • 2848
                      #100
                      G'day
                      That first 4 inches from the head on the handle is the real telling bit. A bit of overstrick and its hit. We have seen the fiberglass hammers and the carbon fibre ones come ..... And break over time. My old east wing is still going regardless. They have it changed "the formular" cause it works.
                      Now axe handles they are going to break in time....
                      The old saying goes .... I've had the same axe for 37 years ... 14 handles .. 3 heads .. But its bin a bloody good axe.
                        • 2848
                        #101
                        G'day
                        All this discussion aside.
                        What the heck . ... Buy a cheapy block spliter and find out what you need after that... It will will work .. But get one with the rubber bit on the handle
                        Regards Dave
                        • applor
                          • Oct 2013
                          • 210
                          #102
                          Heh yeah as it turns out my mum bought an axe she was going to use to chop out an old tree stump but they ended up paying to get a pro grind it out.
                          As a result, she's bringing over her near new axe for me to use. It's not an expensive one though but will do the job.
                          • Greenman
                            • Feb 2013
                            • 1123
                            #103
                            Three cheers for Mum. I am sure that the axe will serve you well for the duration.
                            • applor
                              • Oct 2013
                              • 210
                              #104
                              Tiled on Saturday. Spent some time yesterday building formwork out of MDF for the concrete render.
                              Will be grouting the tiles today and then next weekend we will do the concrete render.
                              • stonecutter
                                • Jun 2007
                                • 2003
                                #105
                                Are you doing anything on the edge, or just caulking it?
                                John Ruskin
