Round shape
  • Mike D
    • Oct 2010
    • 342
    #166
    Re: Round shape
    Thanks Bob for the encouragement, I will take all I can get. My goal is to finish the dome this weekend. Cross your fingers for me.
    - one more row and then I will be able to figure out how to plug it up.
    mike
    • Aegis
      • Jan 2008
      • 436
      #167
      Re: Round shape
      BEAUTIFUL work on your oven!!!!!!!!!!!!! wow!!!!!!!! Nice tight joints!
      Build Thread:http://www.fornobravo.com/forum/f8/i...ome-15521.html
      Photos: http://groups.yahoo.com/group/brick-...67884/pic/list
      Oven Blog: http://johns-brickoven.blogspot.com/...ven-folly.html
      • Mike D
        • Oct 2010
        • 342
        #168
        Re: Round shape
        -Sooo Close. Did one more row, I think I am ready for a plug.
        -How should I do it? I was thinking of cutting one piece to fit (or 2 actually mortared together, one on top of each other so you would not see a seam). I have a big piece of floor tile that I only used part of. Is that a bad idea?
        -I have seen others mortar pieces together before they put it in as a plug, but I think they were all vertical ones sandwiched together (so you would see the seams).
        -Any thoughts?
        Mike
        • Mike D
          • Oct 2010
          • 342
          #169
          Re: Round shape
          I finished the Dome! Yea that's right. Finnaly. I made two pieces and fit them as tight as possible. Now I get to move on to the Vent.
          Mike
          • brickie in oz
            • Mar 2009
            • 3445
            #170
            Re: Round shape
            Nice neat fit from underneath..
            My Build.
            Books.
            • GianniFocaccia
              • Jun 2009
              • 1645
              #171
              Re: Round shape
              Nice job, Mike. Very clean upper courses and plug. This baby's gonna cook!
              John
              • Mike D
                • Oct 2010
                • 342
                #172
                Re: Round shape
                Thanks Brickie and and John, it feels great to get that dome done. I can't believe I did it.
                Mike
                • eprante
                  • May 2009
                  • 282
                  #173
                  Re: Round shape
                  Mike,
                  Very nice and clean work. Now on to the outer arch and vent. A whole new set of challenges. Everybody seems to do this stage a little differently but it always seems to work out ( well almost always). Great work, enjoy the process!
                  Eric
                  • Dino_Pizza
                    • Feb 2008
                    • 1036
                    #174
                    Re: Round shape
                    Yaaaa! Congratulations Mike. Nice shot of the finished dome from inside. Nice keystone too. I can see all the work you did grinding the edges and angles to make that plug fit in just right. It can all dry out now while you work on the arches.
                    -Dino
                    My Oven Costs Spreadsheet
                    My Oven Thread
                    • Sharkey
                      • May 2010
                      • 150
                      #175
                      Re: Round shape
                      Nice work Mike. Keep the updates coming.
                      Sharkey.
                      • Mike D
                        • Oct 2010
                        • 342
                        #176
                        Re: Round shape
                        OK- lets keep things moving. How deep is the vent opening supposed to be? Would a half brick deep be enough. I have been looking at so many arches and vents it's crazy. Everyone does it differently. I am thinking of using a ceramic flue pipe, and have seen people cut them and do a lot of crazy stuff to them. I see most people say an 8" pipe is ideal or normal. My oven is about 39". I don't want my entry too deep, I was thinking of using a brick depth, then having a half brick opening to vent up. If a half brick depth is too shallow, would it make a difference if it was wide (like Les' flew).
                        - Any thoughts?
                        - And thanks for the cheers, guys.
                        Mike
                        • brickie in oz
                          • Mar 2009
                          • 3445
                          #177
                          Re: Round shape
                          A half brick will be too small, you really need 1x1 brick to stop the smoke finding the easiest way out which is the door entry.
                          My Build.
                          Books.
                            Re: Round shape
                            It's the area you end up with that's important. So if you want to go half a brick deep, then go two or preferably three wide. You should funnel the entry to the flue pipe so that the smoke has somewhere to gather. A shallow entry is waY easier to manage when cooking IMO.
                              Re: Round shape
                              On second thoughts ahalf brick is probably getting too shallow for the size of your oven. Think of it a bit like those vacuum cleaner heads that are wide but shallow (even shallower than the pipe to which they deliver. This is my set up, the entry depth is the same size as the pipe diam. (5") but more than three times as wide.
                              Sorry, wrong pic
                                Re: Round shape
                                this is the one I meant
