Re: Cloita's 42" Pompeii in Plainfield, IL
Also here's my variation on the indispensible tool. Cost approximately $15 at Menard's. It is secured to my wooden template via a brass beveled bushing and two eye bolts. the 5/16" size bolts and a bushing of (can't remember the size) fit together with a slight help from Mr. Sledgehammer, but have just the right amount of pressure to still pivot and stay in place when needed. I need to modify it a bit more since the base coupling is reverse thread on one end and randomly breaks free! I also plan on adding a length adjustment coupling in the middle with lock nuts to secure. The brick jig is from the joist/rafter section and is secured via an "elevator bolt".
