Mississippi 44"
    Re: Mississippi 44"
    Sorry Stonecutter,
    I thought that I was keeping up with the forum . I had been working a 12 to 16 hour a day shutdown/outage where I work. The grey looks great! and matches your stonework. I love the "old world" look.
    I understand what you are referring to but, the term "watertable" throws me a little. I live in an area where local building terms do not always match the "official" terms.
    • stonecutter
      • Jun 2007
      • 2003
      #407
      Re: Mississippi 44"
      Originally posted by Gulf
      Sorry Stonecutter,
      Thanks Gulf! I went with the grey because there is going to be a lot more granite when I finally get some time for finishes, and I thought the other colors matched too well...I wanted contrast for this particular element.
      Watertable in masonry is a horizontal projection that acts as a ledge for water running down the face of a structure, to keep it off the lower foundation ( or area below the watertable.) Also known as a band, string, or belt course.
      Old World Stone & Garden
      John Ruskin
      • Tscarborough
        • Oct 2009
        • 3341
        #408
        Re: Mississippi 44"
        More importantly, it is used as both a visual and physical separation between dissimilar materials. Usually between stucco and stone, but also between clay and cementious units. It allows for a flashing point, and also allows for the differential in expansion and contraction between dissimilar materials.
        On some applications, primarily on the interior or weather protected areas it serves as a visual cue more than a construction joint.
          Re: Mississippi 44"
          I am familiar with the term ledge, as in window ledge or door sill. Masonry or carpentry, they are always sloped slightly away from the home. Or in this case oven. That is what I had planned to do for my concrete landing. Slope it gradually away from my entry.
          Am I on the same page with ya'll ?
            Re: Mississippi 44"
            • brickie in oz
              • 3445
              #411
              Re: Mississippi 44"
              Theres an echo in here.....
              • stonecutter
                • Jun 2007
                • 2003
                #412
                Re: Mississippi 44"
                As far as sloping the landing, yes you are. Water is the enemy of all construction. I always set a slight pitch on mine or grind one in like I'm doing with the current build. Unless they are completely out of the weather and under cover, it provides good insurance that water won't run into the vent area.
                But a landing wouldn't really be considered watertable because it doesn't wrap the structure..though it does some of the same things.
                John Ruskin
                  Re: Mississippi 44"
                  Thank's Stonecutter,
                  My antique building experience always included a step down from the finished floor to the exterior levels (porches etc.) Also, just to explain the differences in local terminology, the "prow gable" that you referred to on another thread was commonly called a "boat bow" down here .
                  Brickie,
                  As for as the "echo" is concerned, I've lived with a blonde for nearly forty years. Forgive me, if that one went over my head . Some of it may have rubbed off .
                  • stonecutter
                    • Jun 2007
                    • 2003
                    #414
                    Re: Mississippi 44"
                    Gulf,
                    The echo comment was because of a double post
                    John Ruskin
                    • stonecutter
                      • Jun 2007
                      • 2003
                      #415
                      Re: Mississippi 44"
                      Boat bow huh? I always thought that term referred to more of the ridge line shape, not to an extended gable. Local terms have always interested me, you see it a lot with masonry and with how loose aggregate is described from place to place.
                      John Ruskin
                        Re: Mississippi 44"
                        Gulf,
                        Oops!
                        I hate it when that happens .
                          Re: Mississippi 44"
                          I got a little time this afternoon to get a slurry coat on the landing and ledges. I didn't get any pics. They don't look that much different anyway.
                          On the way back from from a Mothers Day family gathering, I stopped by a local sawmill to pick up some tomato stakes. They are 1" X 1" spacers used to separate the hardwood lumber while drying in the kiln.
                          All of this is outside of the gate free for the taking.
                          All oak, mostly red oak.
                          I feel for those who live in areas where hardwood is hard to come by. I am truly blessed .
                          • brickie in oz
                            • 3445
                            #418
                            Re: Mississippi 44"
                            Whoah dude, whats your address Im coming over for the free firewood.....
                            I hope you took lots of it, there is every type needed in them piles from kindling to good firing pieces.
                            • Greenman
                              • Feb 2013
                              • 1123
                              #419
                              Re: Mississippi 44"
                              That is quite a resource stream. No chainsaw involved. How much time would that free up for worthwhile pursuits?
                              Cheers ............ Steve
                              Cheers ......... Steve
                              • banhxeo76
                                • 194
                                #420
                                Re: Mississippi 44"
                                You got to be kidding!?! How far is that sawmill from New Orleans? I would open a WFO bakery within one mile from that place. I just spent about $265 for a full cord of red oak!
                                Who Dat?
                                Tu Dat
                                If you feel lost with building your WFO, just pray to St. Stephen who is the patron saint of bricklayers.
