Mississippi 44"
    • 2848
    #436
    Re: Mississippi 44"
    Gudday Gulf
    Just saw you brick splits , amazing, never seen any thing like those before. Certainly makes the job of covering the dome nice and neat.
    I'm covering my dome with brick as well but a bit more of a rustic effect as I'm using a brick bulster. Takes some time .... But what the hell with the oven I have all the time in the world to fiddle along as I wish.
    I inspired by those brick splits as I still have to tile the surface around the oven...might even have to use a brick saw after all this time.
    • brickie in oz
      • 3445
      #437
      Re: Mississippi 44"
      Gudday Gulf
      Bunnings used to sell them in the tile section, failing that try a tile shop.
      My mate cuts them for Boral.
        Re: Mississippi 44"
        Dave,
        The splits that I have are all face cuts. They are a little rough, uneven, and different sizes. The interior cuts of the brick are usually identical thicknesses. In my neck of the woods most floors and a few counters tops are done with the interior cuts. The face cuts are more difficult to install for an even finish. But that is what I wanted for the dome to keep with the old brick look.
        I hope Brickie's lead helps you find the right product for you .
        I do like love the look of your brick oven and chimney. I can only admire the work that has gone into it, and especially the fitting of the dome brick with a brick set .
        It is really looking great!
          Re: Mississippi 44"
          Well, I almost had this post finished and accidently closed the d@mn window.
          I knew that the tear drop was coming because of the lack of inverted v's forming in the head and bed joints where the dome meats the chimney.
          Oh well, just fix it and go on. It's hidden under a shelf anyway.
          The hole in the middle is a 1" threaded pvc fitting for the vent.
          I kept the joints raked and swept as I applied the splits. Unless someone looks real close they would think that it is finished. And that is the way the dome will probably look for some time. I intend to tuck point the joints but, not before a few other things get done.
            • 5260
            #440
            Re: Mississippi 44"
            Gulf,
            Looks very fine, seems you can't get away from building some type of brick dome............you see those maters being grown in AZ? My seedlings are beginning to do well.
              Re: Mississippi 44"
              Thanks? Russell,
              My maters got a late start for our growing season. But, I think they will be doing just fine when most others have fizzled out down here. Yes, I saw those pics and was a little jealous . Well there is always next year. The seeds from these San Marzanos will get an early start. That is if they are ?heirloom? tomatoes. I think that I read somewhere that they were. If not, I still have about 20 or so left from what you sent me .
              • Kurtloup
                • Jan 2013
                • 147
                #442
                Re: Mississippi 44"
                Looks great. At this time, I'm planning to brick my dome with half bricks. The splits you used look easier.
                  Re: Mississippi 44"
                  Thank's Kurt,
                  They are relatively easy to apply, if the surface that they are applied to is uniform. I took a few extra pains to get the dome fairly close to being a true sphere with the revolving vcrete form before applying the stucco base.
                  Even then, I did notice where a few small humps and low spots in the stucco layer required a little adjusting with the amount of "butter" from the 3/8" notched trial. Some times it took a thicker or thinner brick to make up the difference.
                  I love the look of a brick finished pompeii oven. I'm looking forward to see your finished dome.
                  • stonecutter
                    • Jun 2007
                    • 2003
                    #444
                    Re: Mississippi 44"
                    You got me green there, Gulf. Looks very good, professional even. Progress has stopped on mine, late work days and full weekends with no end in sight.
                    Old World Stone & Garden
                    John Ruskin
                    • mrchipster
                      • Apr 2010
                      • 1502
                      #445
                      Re: Mississippi 44"
                      . Really nice Gulf, a very unique look. I agree that there is always something else to do when the current version looks great to others but not perfect to the originator, or in your case ARTIST...
                      Chip
                      Chip
                      • V-wiz
                        • Oct 2012
                        • 737
                        #446
                        Re: Mississippi 44"
                        Looks great. I may have missed it but what stone is that?
                          Re: Mississippi 44"
                          Thanks ya'll, very much!
                          V-wiz, They are mostly face cut flooring splits from old brick . I got 3 cuts from each whole face brick.
                            Re: Mississippi 44"
                            I took a little time away from brick ,other than cutting the fire brick for the very last heat break. That being between the entry and the landing.
                            I had to spend a little time on the yard this weekend, but managed to work on some oven tools. I found these bamboo
                            cutting boards at "Walley World".
                            I cut and notched them to fit the spacing sticks that I mentioned earlier. The oak sticks are used to space hardwood lumber in a kiln numerous times before they are discarded.
                            They ended up with a payload of 11" X 12 ".
                            The handles may be a little long but they will allow me to cut them down as I see fit, with some experience.
                            • Tscarborough
                              • Oct 2009
                              • 3341
                              #449
                              Re: Mississippi 44"
                              If you have the capacity, cut them full of slots. The slotted peel is a miraculous thing.
                                Re: Mississippi 44"
                                If it is made out of wood, I have the "capacity". Can you elaborate ? .........On second thought,I've seen the metal slotted peels.
                                I think ,that I could do that with the wooden peel, if you think that would work,
