Jack lines. What is the difference between the string used for them and that used for horizontal stringlines? (Not for you, Gulf, other readers)
Tscar, you may have underestimated me . It has been a few days and no bites. Back in the day we always cut ours off the same roll of thin nylon twine as we did for the course lines. That was also the same roll which we made the staging for out trot lines, but I digress.
What is the difference?
Reason: spelling
I agree with that. For columns I usually set four vertical strings for the corners and use a level for the individual courses. In a shady dark place, with these old eyes of mine, I find it a little easier to see that bright orange string than that damn near invisible bubble .
I forgot to add this expanded pic of the damper control tunnel. The short piece of pipe sandwiched between the washers places the ceramic fiber rope in a little bit of compression. That seems to expand it nearest the outside of the sheath. Not sure if that is important but, I hope it seals off a very small route for the flu gasses and or fire . Damn, I said the F word .
Are you building a castle in Mississippi? Everything looks fantastic by the way!
Thanks Tu,
No, just the most difficult 8' X 10' covered that I have ever attempted .
Wouldn't change a thing though. This is the best therapy I have had since getting out of the nervous hospital .
Hey, the structure is plumb and level, the coursing is a bit, well, not.
Just kiddin T,
The wave looks great and had to been a pain in the as to marry with the level courses. I like working a little outside of the box myself .
