K79 Oven Build
    • 9216
    #136
    Re: K79 Oven Build
    Originally posted by K79
    Ok guys, my 36" oven..... do I use a 7" or 6" chimney as the FB plans call for? Also the height of my chimney... 36" or 48". Either one will clear the top of my enclosure. There's nothing around my WFO to obstruct air flow like trees etc...
    For a 36" oven a 6" flue is adequate, but you need to go to 8" for a 42" oven. So a 7" should be plenty for yours. If you use a 6", then perhaps use the taller flue. Like as has been said before, you can't really over flue a front flued oven, but you can under flue it.
    • K79
      • Nov 2012
      • 391
      #137
      Re: K79 Oven Build
      Ok so this isn't my oven, but it's part of my master plan. I finished my 620 sf patio in 3 days. All that's left to do is the firepit, some planters, and my WFO !!
      Here's a picture of the hardest worker on the job !
      Link to my oven build on YouTube:
      http://www.youtube.com/watch?v=Ujb7lqVcSzQ
      • Greenman
        • Feb 2013
        • 1123
        #138
        Re: K79 Oven Build
        Shows great promise. I hope your apprentice is going to stick with the whole build.
        Cheers ............ Steve
        Cheers ......... Steve
          • 5264
          #139
          Re: K79 Oven Build
          Nice looking paver patio to compliment your WFO.
          • K79
            • Nov 2012
            • 391
            #140
            Re: K79 Oven Build
            I'm wondering how many layers of brick you can do at once when you first start laying brick. Should you only do one "ring" at a time and let the mortar harden before you start the next layer?
            • kbartman
              • Feb 2013
              • 572
              #141
              Re: K79 Oven Build
              Take this with a grain of salt, only from the experiences of my first three courses. I would say the more the merrier. If your quick and able to keep the bricks and mortar moist……….. I found that you can tap concentrically inward around the courses, tighten and correct any angle error and levelness across the course, if it stays moist. Gravity is our friend; the higher we get up in courses the tighter they will bond if they are moist enough and the whole course is completed. I also think several courses at a time would apply. I also found that as the mortar begins to set and becomes firmer. I will check for voids in the mortar joints any voids are easily found by compressing the joint a little, if it remains firm it is void free. Using firm mortar easily found around the oven in different states of dryness you can find the right firmness to pack the joints tightly. Use a tool the size of the joints, Allen wrenches work well. This may be may be my anal retentiveness kicking but I think it will make a better build.
              Pics included of the anlge locator tool used to check angle of each brick and a level for leveling across the courses.
              Respectfully,
              KB
              My build
              • K79
                • Nov 2012
                • 391
                #142
                Re: K79 Oven Build
                Any special trowel you guys use? I'm taking off work this Tuesday and Wednesday to start my brickwork !!! Also, what would you guys say is the correct consistency for the high heat mortar? Also I have a very large print out of my oven floor on paper. Can I lay that down on my hearth slab and build my oven over that? It'll just burn over time, I can't think of any negative effects.
                • kbartman
                  • Feb 2013
                  • 572
                  #143
                  Re: K79 Oven Build
                  I'm using a square edge trowel about a 1 1\2" I bought a V type trowel also and haven't found it useful. I am using Demon High heat mortar a Premixed in 3 gal pail made by Plybricko. When I opened the pail the first time quite a lot of liquid was on top after mixing the consistency of maybe peanut butter but a lot more slippery. I found that in order to get a good bond on all surfaces was to apply a very thin layer of mortar to all joining surfaces first, then butter for thickness. I am shooting for 1/8” joints. Which to my surprise was the just about enough with very thin layer first applied. Carful on tapping brick this will affect the adjacent fresh lay of brick. A wiggle works best to squeeze out excessive mortar. I tightened the mortar joints on the next courses.
                  Ps. Soak bricks I was suprised of all the air coming out of the brick when placed in water.
                  Hope this helps
                  Respectfully,
                  KB
                  My build
                  • kbartman
                    • Feb 2013
                    • 572
                    #144
                    Re: K79 Oven Build
                    Originally posted by kbartman
                    After working night shift the last few days, I did some inspections on the courses that already lay. I have been trying to keep the mortar moist as possible with spray bottle and water hose. The suppliers ask me if I understand the Demon mix was for tight joints under 1\4". Understood but thought I might get away with the joints between the courses being a little larger. I?m now not so sure.
                    Attached are some pics of the curing I think I will use the bevel scraps between the following courses any suggestions is appreciated.
                    The sides of the oven that get morning and afternoon sun shows signs of premature curing
                    Ps. The dreded Lovebug season has began.
                    K79 I posted this on my threads pics also.
                    Again hope this helps.
                    Respectfully,
                    KB
                    My build
                    • K79
                      • Nov 2012
                      • 391
                      #145
                      Re: K79 Oven Build
                      thanks kbartman. I'm using Heat Stop for my high heat mortar. No instructions on the bag. I'm going to try and give them a call. What is the normal procedure? You need to spray the mortar until it cures? Roughly how long is that? I'm planning to cover my dome while not working on it with a tarp?
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        #146
                        Re: K79 Oven Build
                        Kbartman, you really do not want to use that refractory cement on your build. It is made for MAXIMUM joint width of 1/4". It is also water soluble, so wetting it is not doing any good. It is a heat-set mortar.
                        For Heatstop, mix no more than you will use in 10-15 minutes. Slowly add water until is a tad wetter than peanut butter. Once it begins to set, you can re-temper it once (remix it), but after that throw away any left and mix a new batch. It does not need to be kept moist to cure.
                        • K79
                          • Nov 2012
                          • 391
                          #147
                          Re: K79 Oven Build
                          Can you please explain the re-temper procedure? Basically at around the 10-15 minute mark if it starts to change consistency I can mix it and it'll be good for about another 10 minutes?
                          • K79
                            • Nov 2012
                            • 391
                            #148
                            Re: K79 Oven Build
                            Anyone see any issues with me leaving a paper stencil between my insulation board and my oven floor? I have a stencil made on my plotter and would like to lay that on my insulation board and lay my brick on it so I can check all of my cuts and fit them as I go. Only issue... no removing it once the brick is in place.
                            • SCChris
                              • Jun 2009
                              • 1213
                              #149
                              Re: K79 Oven Build
                              I don't see any issue with leaving the template, without oxygen it'll just carbonize. I would take off any excess you have access to afterward.
                              Chris
                              • K79
                                • Nov 2012
                                • 391
                                #150
                                Re: K79 Oven Build
                                I can't believe I'm about to say this but I'm not sure now if I want to do the arch entry like Kbartman or the style with the stright sides like Ken524's oven. Advantages/disadvantages of each? Supposed to be starting my brickwork tomorrow
                                my name should be Indecisive79
