K79 Oven Build
Re: K79 Oven Build
So I finally broke ground last night. I had to bust through 1' of frost. I came across a little seedbump in the last photo but nothing major
Re: K79 Oven Build
Good morning everyone,
I got my slab poured this weekend. Now I'm curious when dry stacking my block stand is it ok to have some gaps between the blocks? Due to the fact that an 8x8x16 cinder block isn't exactly those dimensions I need to put a little space between them so that my stand is square. Is this ok to do? What is the max gap if it's acceptable?
Re: K79 Oven Build
By the time you core fill them they aren't going anywhere. Part of the text in your post was lost. I assume that is where the numbers are hidden. You might try making the pics a bit smaller, that is probably the cause.
You shouldn't end up with significant gaps. I ended up with a couple about 10mm in mine but I filled those with a view to plastering the lot when I am done.
Happy stacking
SteveCheers ......... Steve
Forno Food Pics https://www.facebook.com/media/set/?...1&l=1d5ce2a275Comment
Re: K79 Oven Build
I shrunk my photo, thanks for the heads up. My max gaps would be about the same as yours are.By the time you core fill them they aren't going anywhere. Part of the text in your post was lost. I assume that is where the numbers are hidden. You might try making the pics a bit smaller, that is probably the cause.
Happy stacking
SteveComment
Re: K79 Oven Build
When dry stacking cinder blocks what do you use if you need to shim a little to level out your block stand?Comment
Re: K79 Oven Build
Mortar, getting first course level most important. BTW nice start. saw the plate compactor in the background of one of your pics, doing it right.Comment
Re: K79 Oven Build
Hey Guys...
Status update. Block wall up and hearth slab framed out. I'll be pouring that tomorrow afternoon.
Then I'll be laying about 620 sf of patio pavers over the weekend +/- a few days
Then back to the oven. I need to get my lawn re seeded so I figured I might as well get the patio out of the way ! Right
Re: K79 Oven Build
K 79,
Filled all the core!!, not moving any where. You might want to consider drilling some rebar pins in the green cores to so you can tie your hearth rebar grid to the dry stack. May not be a big deal but cheap insurance.Comment
Re: K79 Oven Build
Ok guys, my 36" oven..... do I use a 7" or 6" chimney as the FB plans call for? Also the height of my chimney... 36" or 48". Either one will clear the top of my enclosure. There's nothing around my WFO to obstruct air flow like trees etc...Comment
Re: K79 Oven Build
Post 109. 7" it is. Man it's been a looooong day.Comment
