K79 Oven Build
  • K79
    • Nov 2012
    • 391
    #121
    Re: K79 Oven Build
    Originally posted by mrchipster
    I think pre drying is a good idea less chance for trapped moisture.
    Oh, by the way most of us have tools we use to build our ovens but for the life of me I cannot figure out what you are using the bicycle pump and tree trimmer for...
    Chip
    You never know when you'll need a tree trimmer or a bike pump.... you never know
    Link to my oven build on YouTube:
    http://www.youtube.com/watch?v=Ujb7lqVcSzQ
    • K79
      • Nov 2012
      • 391
      #122
      Re: K79 Oven Build
      So I finally broke ground last night. I had to bust through 1' of frost. I came across a little seedbump in the last photo but nothing major
      • Laurentius
        • Nov 2010
        • 923
        #123
        Re: K79 Oven Build
        Its Jimmy, Jimmy Hoffa!
        • K79
          • Nov 2012
          • 391
          #124
          Re: K79 Oven Build
          Good morning everyone,
          I got my slab poured this weekend. Now I'm curious when dry stacking my block stand is it ok to have some gaps between the blocks? Due to the fact that an 8x8x16 cinder block isn't exactly those dimensions I need to put a little space between them so that my stand is square. Is this ok to do? What is the max gap if it's acceptable?
          • Greenman
            • Feb 2013
            • 1123
            #125
            Re: K79 Oven Build
            By the time you core fill them they aren't going anywhere. Part of the text in your post was lost. I assume that is where the numbers are hidden. You might try making the pics a bit smaller, that is probably the cause.
            You shouldn't end up with significant gaps. I ended up with a couple about 10mm in mine but I filled those with a view to plastering the lot when I am done.
            Happy stacking
            Steve
            Cheers ......... Steve
            • K79
              • Nov 2012
              • 391
              #126
              Re: K79 Oven Build
              Happy stacking
              Steve
              I shrunk my photo, thanks for the heads up. My max gaps would be about the same as yours are.
              • K79
                • Nov 2012
                • 391
                #127
                Re: K79 Oven Build
                When dry stacking cinder blocks what do you use if you need to shim a little to level out your block stand?
                  • 5264
                  #128
                  Re: K79 Oven Build
                  Mortar, getting first course level most important. BTW nice start. saw the plate compactor in the background of one of your pics, doing it right.
                  • K79
                    • Nov 2012
                    • 391
                    #129
                    Re: K79 Oven Build
                    Hey Guys...
                    Status update. Block wall up and hearth slab framed out. I'll be pouring that tomorrow afternoon.
                    Then I'll be laying about 620 sf of patio pavers over the weekend +/- a few days
                    Then back to the oven. I need to get my lawn re seeded so I figured I might as well get the patio out of the way ! Right
                      • 5264
                      #130
                      Re: K79 Oven Build
                      K 79,
                      Filled all the core!!, not moving any where. You might want to consider drilling some rebar pins in the green cores to so you can tie your hearth rebar grid to the dry stack. May not be a big deal but cheap insurance.
                      • K79
                        • Nov 2012
                        • 391
                        #131
                        Re: K79 Oven Build
                        Ok guys, my 36" oven..... do I use a 7" or 6" chimney as the FB plans call for? Also the height of my chimney... 36" or 48". Either one will clear the top of my enclosure. There's nothing around my WFO to obstruct air flow like trees etc...
                        • Tscarborough
                          • Oct 2009
                          • 3341
                          #132
                          Re: K79 Oven Build
                          It is not so much the oven size as it is the inner door opening size.
                          • K79
                            • Nov 2012
                            • 391
                            #133
                            Re: K79 Oven Build
                            Right I was just referencing my oven.
                            • Tscarborough
                              • Oct 2009
                              • 3341
                              #134
                              Re: K79 Oven Build
                              So what size is the opening?
                              • K79
                                • Nov 2012
                                • 391
                                #135
                                Re: K79 Oven Build
                                Post 109. 7" it is. Man it's been a looooong day.
