Re: K79 Oven Build
For a 36" oven a 6" flue is adequate, but you need to go to 8" for a 42" oven. So a 7" should be plenty for yours. If you use a 6", then perhaps use the taller flue. Like as has been said before, you can't really over flue a front flued oven, but you can under flue it.
