K79 Oven Build
  • V-wiz
    • Oct 2012
    • 737
    #241
    Re: K79 Oven Build
    Originally posted by K79
    So I've been covering my oven with a tarp to keep it safe from the rain we've been getting up here in Maine. I read in another post NOT to cover it in a tarp and to spary it down. Can anyone verify this? I'm using HeatStop and I thought I didn't need to wet the mortar? Also can I leave the tarp over my oven?
    I covered my dome after working on it to keep some moisture in the mortar so the mortar doesn't dry too fast, however you must give it some air to breath also, don't completely cover it. After 1-2 days i would remove the tarp. Basically after the mortar hardens i would remove the tarp.
    • K79
      • Nov 2012
      • 391
      #242
      Re: K79 Oven Build
      You don't have to worry about it raining on the brick for the month or so you're working on the dome?
      Link to my oven build on YouTube:
      http://www.youtube.com/watch?v=Ujb7lqVcSzQ
      • K79
        • Nov 2012
        • 391
        #243
        Re: K79 Oven Build
        I got my support for my inner arch complete today on my lunch break. It went faster than I thought. My plan is to put some 2x4's under it with some cedar wedges on both sides to lift to the correct elevation. Once my arch is nice and solid, just slip the cedar shingles out and done
        • V-wiz
          • Oct 2012
          • 737
          #244
          Re: K79 Oven Build
          You want it to eventually dry, also ou dont want the insulation to get wet.
          • K79
            • Nov 2012
            • 391
            #245
            Re: K79 Oven Build
            Ok so you don't want it to keep getting wet right, but it's ok if it got wet from my fireclay when I put it down to level my insulation board.
            • K79
              • Nov 2012
              • 391
              #246
              Re: K79 Oven Build
              Ok, here is a pic of Ken's inner dome. Mine should be similar to his. Anyone concerned with the center brick having it's taper smaller at the top than the bottom... any other concerns?
              • V-wiz
                • Oct 2012
                • 737
                #247
                Re: K79 Oven Build
                Correct, in my case i didn't use water, just dry sand and fireclay.
                  • 5264
                  #248
                  Re: K79 Oven Build
                  K79,
                  I am not sure where you are at on your arch but a tapered arch would help with a smooth transition from the dome to the arch. Here is a link showing how this done on a arch similar to yours. Hope this helps
                  http://www.fornobravo.com/forum/8/oc...tml#post119582
                  • V-wiz
                    • Oct 2012
                    • 737
                    #249
                    Re: K79 Oven Build
                    Looking like a tear drop.
                    • Les
                      • Sep 2005
                      • 2945
                      #250
                      Re: K79 Oven Build
                      Ken's oven has been working for years so it obviously isn't that big of a deal. Try and avoid the notorious "droop" You will be fighting to get back to a true circle as you go vertical.
                      • V-wiz
                        • Oct 2012
                        • 737
                        #251
                        Re: K79 Oven Build
                        Even if you do run into the tear drop its okay. The oven will still function just fine. If you run into the drop all you have to do is add a key stone to avoid it, then start a new chain of bricks it will solve the problem. Ask me how i know.
                        • K79
                          • Nov 2012
                          • 391
                          #252
                          Re: K79 Oven Build
                          Here is what the back of my arch looks like. I need to (obviously) bring my ring around here in the back. Confusing....??..??
                          Any suggestions?
                          The Front:
                          • K79
                            • Nov 2012
                            • 391
                            #253
                            Re: K79 Oven Build
                            I feel like I'm just crossing my fingers here at this point ... very unsettling... I don't like it
                              • 5264
                              #254
                              Re: K79 Oven Build
                              K79,
                              It does look like you are at a point where you can do a taper arch using a full brick. Just a consideration, the time spent doing this will pay off dividends in the arch to dome tie-in. Take a look at the link I sent you.
                              • K79
                                • Nov 2012
                                • 391
                                #255
                                Re: K79 Oven Build
                                Are you talking about the link in your tag? I don't see one anywhere else. Thanks UtahBeehiver !! I can't wait to see this option. If your referring to your oven I'm having a hard time picturing how mine would come together like that. I love it, and I'd love to be able to do something like that.
