View Post
Re: K79 Oven Build
Whatever you decide to use for your form, make sure you can remove it without destroying it, you can use it later as a template for you oven door.
Re: K79 Oven Build
Ok so my opening is 19" wide, 10" high on the ends and 11 1/2" at the center. Any ideas on making the form for my arch?
Also I printed out my oven opening on paper and it looks huge with those dimensions. Must be an optical illusion right.... Those dimensions are from FB ... mostly. The oven openings just look smaller in all the photos I've seen.Last edited by K79; 05-03-2013, 08:22 AM.
Re: K79 Oven Build
K79.
Strive for the best joints you can on the inside of the dome, mortar is your friend on the outside. I strived for as tight of inside and outside joints I could get. If I were to do again I would just focus on the inside and spend my energies elsewhere.
Re: K79 Oven Build
Ok since Les said to "leave it be" I figured this would be a good time to experiment with the mortar and working the brick since I really can't screw anything up since it's good to start with. I quickly found out that planning an oven with all 1/8" joints won't happen. Makes me smile when I remember reading a thread where someone wanted to build one with no gaps at all. I'm now going to plan on 1/4" joints all the way around. Hopefully I'm still leaving myself enough "wiggle" room.
Re: K79 Oven Build
You should be able to just screed the mix to fill the low spots. The fine cracks in the board are no problem.Originally posted by K79 View PostOk guys I only have enough fireclay to go around the perimeter of my ceramic fiber board. Is it ok to level it going around ther perimeter and not smear it across the entire hearth slab. There will some voids under my insulation board. Also I noticed some fine cracks in my board are these oK?
Re: K79 Oven Build
You can do a sand and fire clay mix as well with a notched trowel to help you extended your fireclay
Re: K79 Oven Build
Re: K79 Oven Build
Ok guys I'm in the process of laying my ceramic fiber board. There are some gaps between my fiber board and my hearth slab. How do I level these so my board doesn't crack when the brick is laid. They are about 1/4" at the edge. Can I lay a bed of fireclay between my hearth slab and my insulation board? At a stand still !!!!
Re: K79 Oven Build
No, not Heatstop, it is fine for thin or wide joints.
