View Post
The offset was my hair brain idea to allow for more oven landing counter. By pushing the flue back a couple of inches allowing oven face to also be push back giving me more counter.......
. My original plan was to leave the lintel of the pool wall and use it to support the chimney, with the flue in front of the lintel. I had added additional insulation under the oven, which push the oven dome and insulation into the lintel making me revise my plan
. Now I looking for suggestion on how to support the rear of the chimney. I have a few ideas but have not finalized them. As far a the floor thermal break it seams too me the stainless tubing is the popular option. Although I will probably incorporate Gulf's idea into mine and place some ceramic band on the oven side. I think that will give me the best of both worlds
.My plan for the oven counter is to pour a additional 4 1/2 inches to bring the front of the stand to within 2 inches of oven floor. Incorporated the reinforcement for the counter and any needed chimney reinforcement. My plan is polished concrete counter. Not sure how much I can over hang the oven base, still researching and looking for suggestions.
We still have some time to decide while I remove the arch support and work on the vent area floor. I was hoping someone might fire up their oven and take some readings with there IR temperature gun on each side of their floor thermal break and compare.
..............I was hoping of coming up with a plan by now..........Thanks Stonecutter, You are right, I don't remember any rebar in any old chimney that I've seen.....That gives me a better perspective on building a brick chimney
