Re: My 40" Inch pizza oven in Florida
UtahBeehiver,
I responded on my thread. Bruce
Believe it or not I just did the same thing. I am cross posting to keep continuity of content on by thread. Kbartman, sorry to be cluttering your thread. Bruce
Bruce,
When you get done trimming the Ca Sil to where you want, take your leftover mortar as you lay your bricks and render the sides of the Ca Sil board. The mortar will keep the Ca Sil from getting damaged, broken, dented while you do your dome.
Sorry about the nightmare, still think the meteor is the real threat.
On the other hand looks like I posted too soon regarding the biosoluble board. I emailed Skyline and within a few hours they replied that the compressive strength of the ceramic fiber board is 0.3MPa. This compares to .5 MPa of their comparable CF board. I am going to start trimming floor brick and deal with this issue once that is done. I think I have enough scape pieces of the CF board to replace the biosoluble. Glad I caught this now and not when well into building the dome. Try to get some sleep. I wonder how homeowner's insurance deals evaluates cost of DIY WFO. Regards, Bruce
Bruce,
No I have'nt read your first thread I will though. I got to gets some sleep today I'm working nights. Funny you should mention sink holes. How about giving me a warm fat fuzzy on this one. While cutting the pool deck floor for the foundation I discover a void beneath the concrete slab about 8" X 2'. At the time, I contributed to improper fill around the pool when install 1970 I figure. I filled it in and moved on. Then yesterday I notice a few old step cracks in the wall surrounding the pool.
Is my build doomed for failure from bad insulation or a sink hole........ I sure need some warm fat fuzzies. Off to bed wish me sweet dreams....LOL
Bruce,
Could not sleep woke up to nightmare, my oven and I falling in the sinkhole.
.......... IF you don?t hear from me in while send someone to check on me.
.......LOL....... I hate night shift. Body always wants to be up during the day even when exhausted.
To answer your question, yes still plan on cutting the floor insulation around dome...... As fragile as the insulation is I did not want it crumbling around the dome walls loosing support around the edge I thought I would have a tighter seal between the blanket and board if I cut it later.
Looks like you are not cutting the board to match the dome. Must be nice not having to mess with cutting it to shape. I decided to cut the boards to conform with the dome. Figured I would be able to extend the blanket down to the slab and fully insulate the dome. After cutting the board, not sure it was worth it. Bruce
Al,Originally posted by brickie in oz View PostPlease post some pics of the board so we can determine what we are dealing with.
Not sure you can see everything. I hope this helps:
Originally posted by kbartman View Postfiber board purchased from FB has some inconsistencies in thickness. After trying a notched trowel approach??.. Decided to spread fireclay no sand on all joints to the level out inconsistences.
Pic #1: Worst area around dome. Level held level showing about 1/8" of compression. I wanted to make sure the joints were tight so I set the board against the others by firmly tapping along the joints and sides with the scrap wood before securing to stand floor assuring no movement while setting the floor.
Pic#2: Shows floor insulation installed. My biggest concern was the front left corner. Notice the small pieces. This was my worst joint. While trying to even out the joint, I may have over work the area. Causing loss of the original compression and swelling of board. Which I believe should back compress evenly.
Pic#3: Shows the #2 area after bricks set on for a while.
Pic#4: Shows typical area of the board after brick set very little compression, maybe 1/16? but brick will rock as explained in previous post.
Pic#5&6: Shows a fireclay slurry to help smooth out joints.
I think my biggest mistake was over working the board.
6 PhotosLast edited by kbartman; 04-25-2013, 06:42 AM.
Al,
I'll take some pics when I get home this morning. The over all compression of the board seems ok with three courses set. A slight indention of maybe 1/8". My biggest concern was the bricks rockin on the floor. The sand seems to have solve this. Placing a brick on the insulation and placing pressure evenly down very little compression, as the pressure is applied unevenly or in the corner the brick, would rock slightly. This seems ok and makes sense the board isn't rock hard. Small surface area of the corners would cause more deflection. I may have softened the top layer a little around the joints trying to even them up. All the material is still there just a little softer do to my stupidy.
I feel it should all compress to the original state after the bricks are set. With the floor tightly locked In place it shoud move as one large surface area and evenly compress the board to spec. We could probaly firgure that out. If I remember correctly I think the compression .5 Mpa. Not sure how to figure that.
On another subject I think I read a post of yours that a mason works a arch backwards. Attached is a pic, is this what you mean, start at the top?
PS. Can you see the three y's neatly staggered in the text of the post? I planned that
or is it just stipidity?.................
I hope I have the same luck staggering my course joints, LOL
1 PhotoLast edited by kbartman; 04-25-2013, 07:16 PM.
I dont think anyone is offended, you have made up your mind to press on with the build so everyone just shut up.Originally posted by kbartman View PostBruce,
The fb board is still a concern of mine I'm trusting I made the right decision. hope it don't come back to bite me. Since I decide to move on in my build, no one has posted anything further. Makes me wonder. I hope I have'nt affended anyone with my kidding around. If I did, my appologies to all. I value everyones opinion and need all the help I can get. Feel free to post on my thread.
I made so progress since my big scare on Friday. After the floor was set and first course lay I found some rocking in floor, which I did not like.
Thinking about a tear down at this point, I remembered briefly reading a thread on some putting sand inside the dome for support and someone else sanding the floor. Without any further reading on the subject, I thought to myself, why in the world would some do that? I only envisioned a gritty pizza.
……....... I decide to try a little sand on the floor. Frustrated with the outcome thus far, I thought I had nothing to lose……..
With a hand full of sand and paint brush in hand. I went after the uneven and rocking brick. I brush the sand into the joints and notice a little improvement. Driven by the thought of the tear down I continued …………To make a long story short a few shots with a spray bottle, does wonder to get the sand to flow into the joints………..I know have a rock solid even floor that I’m happy with. As mentioned before, Forno Bravo would not steer us wrong in selling and promoting a product for the floor. The same insulation sold in their kits. Sorry, I should have never doubted. Thanks FB, I could have never made it to this point without you.
A few pic of my progress:
PS. Thanks Utah for the advice, seeing is believing……. I will be modifieing the brick bracket.5 PhotosLast edited by kbartman; 04-24-2013, 03:46 AM.
Thanks for the advice Brickie,Originally posted by brickie in oz View PostSorry, no warm fuzzy feelings to offer.
The FB board means Forno Bravo board which is actually a Calcium Silicate board and doesnt compress nearly as much as Ceramic Fibre board.
Ceramic Fibre board will compress to nearly nothing with enough weight and time.
I did use the Forno Bravo board. I think all will be fine. I think the FB plans are great as a general guide line. I adhered closely to the materials presented in the plans. Forno Bravo has proven success and I feel confident they would not steer me wrong. I think I was frustrated with my floor not turning out as well as it did during lay out on a rock hard surface. I was over reacting and wanted a rock hard surface.
Thanks Chris, I did a bed alignment yes that was the ticket. The saw blade was wore by the misalignment. The new blade has no deflexion and is cutting true even on the very edge of brick.Originally posted by SCChris View PostYou may find that the alignment of the saw is not in line with the rolling bed. There are instructions for adjusting the alignment here on the site..
Chris
The misalignment was defiantly the cause for blade deflexion and premature ware, and failure.
Thanks a million Chris.
Well made some progress today and gave myself a warm fuzzy. Decided to trust the FB plans......all looks well thus far, set the second course and everything is getting sturdy and found no further compression.
I soaked bricks and covered with plastic this allowed repair of any cracks and separations in the first course..... all seems stable at this point.
I knew the” Anglealizer” would come in handy, money well spent.
Notice the packing foam for the joint. This should keep all crap and mortar out of joint between the floor and oven wall.
Incorporated fiber ceramic band to allow for floor expansion keeping ash out and hopefully will prevent dome wall cracks.4 Photos
Originally posted by kbartman View PostI need a warm fat fuzzy from those whom used the fb plans and set the WFO on the fiber board.
Please help
Just as well I saw that you had problems before you got too far.
I know its a bummer but better to rebuild it now than in 2 months time.
Originally posted by brickie in oz View PostAs they say here, bugger.
Its already compressing, not sure how much it will compress.
I thought ceramic fibre board was only good for hot face work with no load.
How far have you got with the oven?Here is the text from the fb plans saying the oven is set on the board.Originally posted by stonecutter View PostThis is not a good that this is happening and you haven't topped out yet. I am wondering how high you are as well.
Please helpAttached Files
I only have the floor set and mortared the 1st course. I than temporarily placed four more courses full bricks on top to check if compression continued. I’ll check this morning and see how much more it has compressed. Spec attachedAttached Files
