Re: My 40" Inch pizza oven in Florida
Congrats, nice feeling huh
Originally posted by UtahBeehiver View PostAdd an engraved heart to the plug and your will be golden with Julie...............She will be peeking inside the dome everytime it clears. Nice work...... I took your advice Utah I'm golden
. I used a three piece plug like yours Utah. Let the celebration begin?????.I?ll set the upper two pieces tomorrow.
Thanks all for your support.
3 Photos
Originally posted by kbartman View PostThanks Guys,
I was thinking this thread was the usual..........
Any way I'm thinking of buying this IR thermometer??..I need everyone?s opinion. Do you like it? Is the range high enough? If you know of a better one or better deal post the address, thanks all.
THERMO TECH Non-Contact Infrared Digital Thermometer w/ FREE Holster (-58? To +1022? F)
It's a few bucks cheaper at amazon.
ThermoTech TT1022 Non-Contact Digital Infrared Laser Tempature Thermometer - Amazon.com
This one has similar specs but much cheaper.
BAFX Products Non Contact Infrared (IR) Thermometer Range of -58F to 1, 022F Includes Battery: Amazon.com: Industrial & Scientific
Originally posted by dusty View PostWow,
I haven't been around for awhile but I'm pretty sure I've never seen a thread this long! You must be doing something right!!!
dustyOriginally posted by chirobuggy View PostIt is a long thread but a good one! Im taking notes as I am still in the first legs of the journey.
Wow,
dusty
Originally posted by kbartman View PostBruce,
Your build is an inspiration to me and others, keep up the good work. I think the biggest challenge is keeping each course as level and concentric and you are able. I think it helped simplify the upper courses and dome closing. I used a 1X2 stick that I cut and sanded to a point to check each course height. The point easily pushed thru any soft mortar on plywood floor. I marked a line on the stick at the inside top edge of brick, after I set the first few bricks of each course. Hope this helps. Looking forward to seeing year next pictures and dome closing.
Originally posted by CSpringsOven View PostBartman, I saw some sketches (I recall) on how you want to finish your enclosure, do you have any final drawings/ideas?
I might be in the market for a few ideas of my enclosure.
Haven?t finalized the enclosure plans, still teetering on the chimney, real brick or faux stucco. I guess I need to get the ironed out soon. My biggest concern with the real brick chimney, is keeping the water out. As tropical as it is here in Florida, keeping my oven and insulation dry, I believe is going to be an ongoing issue. My insulation is still wet from the soaking, I have had heat lamps below the hearth for quite a while and it is not drying out. I think a brick chimney maybe a challenge to keep it dry. I hope I?m able to get it dried out and keep it that way.
Originally posted by Bec1208 View PostKbartman, great looking build. My dome in building up and curious if you have any advice on the upper courses? Bruce
Originally posted by kbartman View PostThanks guys hope to plug her soon............The oven
....Bruce just mortar on upper dome
Looks great. What did you use to render the upper part of the dome?
Add an engraved heart to the plug and your will be golden with Julie...............She will be peeking inside the dome everytime it clears. Nice work1 Photo
