Randy's dreams do come true oven build
  • mrchipster
    • Apr 2010
    • 1502
    #181
    Re: Randy's dreams do come true oven build
    Here is what i did but please look at the earlier entries on this post for more details on the heat break.
    Chip
    • gastagg
      • May 2013
      • 271
      #182
      does the rope go all the way around? if so, how?
      George
      See my build thread here.
      See my build album here.
      • mrchipster
        • Apr 2010
        • 1502
        #183
        Yes, stuffed in from the back side. It is open as you build the flue arch.
        Chip
        • RandyJ
          • May 2010
          • 1191
          #184
          I have one more question. For the vent heat break would this work.
            What ever method you choose, don't forget the reveal! One is not shown in your drawing as is in Chip's .
            • RandyJ
              • May 2010
              • 1191
              #186
              Opps sorry I just did not draw one. But I have a 1 and 5/8" reveal. Thanks for noticing and making sure I don't miss something.
              Randy
              • mrchipster
                • Apr 2010
                • 1502
                #187
                Just another way to do it and I guess when I think about it your way is much simpler.
                Chip
                  Probably not easier, but I went with a knotched design. It gave me full 3" reveal. And, good "side to side" room to work the oven through the flu entry. That's probably about as much room as some have gotten with the "flared" entries. Just another way to "skin the cat" .
Name:	Heatbrak Notch.jpg
                  • RandyJ
                    • May 2010
                    • 1191
                    #189
                    Ok that is what I was thinking. Good to hear from someone else though. Gulf I was first thinking of doing it the way you did but now I am looking for quick and easy. I like to say [give a lazy man a difficult job and watch him find a easy way to do it. ] thanks for the response.
                    Randy
                    • gastagg
                      • May 2013
                      • 271
                      #190
                      OK, I have two questions on Chip's diagram, which I wrote on the diagram. I can be a slow learner...
                      George
                      • mrchipster
                        • Apr 2010
                        • 1502
                        #191
                        yes and yes
                        Chip
                        • RandyJ
                          • May 2010
                          • 1191
                          #192
                          Chip I have a question. For the heat break gap could I fill it with just blanket scraps or should I use ceramic rope? And what should I ask for for sealing the gap on the inside, so I know what to ask for at SS.
                          Randy
                          • joeykramer
                            • Apr 2013
                            • 86
                            #193
                            are you going to have any support in the middle of your frame? Are you concerned that the weight of the hearth and oven is will not be supported by just a perimeter of CMUs?
                            i ask because as i am getting ready to build my 42 corner build, i have some concern as well. I too, was going to go with 72" sides.
                            thanks!
                            • RandyJ
                              • May 2010
                              • 1191
                              #194
                              Hey Joey how are you. I have no worries at all about the stand. Most of the weight is within a foot of the edge. My slab is also 6" thick with a lot of rebar in it as well. And my front Archie also part of the poored slab and is almost 12" thick. There is rebar and core filling in all the block. So it is pretty much a bomb shelter. Oh and my base is 70"x70"so pretty close to what you are thinking.
                              Randy
                              • RandyJ
                                • May 2010
                                • 1191
                                #195
                                Well I got my ceramic rope and sealant for my heat break. It sure is nice to have a local place that you can go in to tell them what you want to do and they say here you go this is what you need.
                                Randy
