Originally posted by Guerito
View Post
I'm definitely no engineer either! But the idea was to have a semicircle starting at the top of the soldier course. Just like you mentioned. I was in fear of having my opening too high with semicircle on the ground, so I did the first course with the bricks up right to give a little rise to whole thing. If my theory is correct, this will create a higher dome and hold heat better with the size of my door opening. FYI, my opening is 20" wide with the begining of the arch at 9" maxing out at 11". Also, this is a 42" ID oven.
