2024 Neapolitan oven build
  • daidensacha
    Originally posted by RandyJ View Post
    Wow that is looking beautiful. Wish I was better at wood working. I would love to make a table like that.
    Randy
    Thanks Randy.
    I’m kind of lucky living where I am in Bavaria, that Oak around here is so plentiful. I’m slowing using it everywhere in my house, shelves, walls, floors, bench tops.
  • daidensacha
    Originally posted by atak View Post
    My compliments for the build. You are truely a craftsman. I am building one too but will do it the Italian way. Cheers, Adrian.
    What do you mean the Italian way?
    I planned my oven down to the last detail prior to starting, using the Forno Bravo plans, and decided on the Neapolitan dome. I stuck to the dimensions laid out by Forno Bravo. The dome and opening are precise, and it is outperforming any expectations I had. I’m really happy that I insulated so well too, because I’m able to use the oven for 5 days using the retained heat from heating it for the initial pizza bake.
  • daidensacha
    Dome render
    I’ve been a bit busy with multiple projects this spring. A couple of days ago I had a window of time and the weather was fine so I put the second last coat of render on the oven dome. Been waiting for it to set sufficiently so I can put the last layer.
    I’m adding reinforcing mesh where the dome meets the stand and chimney to prevent the possibility of cracking in those spots as it dries. I’m looking forward to to cleaning it up and giving it a final lick of paint.
Name:	IMG_8650 Large.jpg
ID:	465749 Click image for larger version
Name:	IMG_8655 Large.jpg
ID:	465748 Click image for larger version
Name:	IMG_8656 Large.jpg
ID:	465747 Click image for larger version
Name:	IMG_8657 Large.jpg
  • Alex_FB
    Really looking good
  • atak
  • RandyJ
    Randy
  • daidensacha
    Oak Table
    I picked up a nice slab of oak about 6 weeks ago. 3300 x 800 x 85mm after I finished cleaning it up. It’s still not fully dry, as it was sliced in end of 2023. So I‘m letting it be for a couple more years before finishing it off with a router sled to flatten it perfectly.
    I was on the lookout for some rough cut dry oak, and a few weeks ago found some that was cut 13 years ago. I took it to my local sawmill where I was able to use the machines to cut it down to size, and build it into a nice solid oak stand. I did that this week, and got it home yesterday. Looks really nice on the terrace next to the pizza oven.
Name:	C2741C5E-31F9-4C8B-98F0-D15E917FE13C Large.jpeg
ID:	465131 Click image for larger version
Name:	59E9C669-45D2-4F05-B88B-7294C2742B42 Large.jpeg
ID:	465132 Click image for larger version
Name:	IMG_8549 Large.jpeg
ID:	465130 Click image for larger version
Name:	IMG_8551 Large.jpeg
ID:	465129 Click image for larger version
Name:	IMG_8558 Large.jpeg
    It‘s heavy, so I know no one will ever be able to walk off with it . Sits 12 people easily. I have 2 x 3300 x 400 x 50mm slabs of oak I also machined down this week. Now to work on building some legs that will match the table.
    So we‘re in for some 22C days this week, perfect weather to work on finishing the final layers of render on the dome.
  • Toiletman
    Originally posted by daidensacha View Post
    A little bit of tiling completed today
    Making the most of the warmish spring days. Today I decided to add some tiles under the granite worktop, and at the back of the worktop on the brick wall. Hand made tiles from Italy, a color that reminds me of earlier days diving in Australia. Lived near, and spent a lot of time in the ocean, so it’s a strong connection, and nice to include a color that triggers fond memories. Turquoise green.
    Fantastic work again! I was just telling myself that I wouldn't want to spend a load on a granite top and then I see this... what a work of art! The tiles are also a nice choice, and indeed great to trigger memories of the ocean. Were you underwater diving or surfing/swimming on top? Enjoy your holiday and here also the great weather has gotten me out of hibernation to finally finish the oven...
    Coming along very nicely. These ovens are a labor of love.
  • daidensacha
    I still have to grout, but I’m taking a 10 day holiday on Friday, and will get into when I return.
Name:	IMG_8353 Large.jpeg
ID:	464461 Click image for larger version
Name:	IMG_8346 Large.jpeg
ID:	464462 Click image for larger version
Name:	IMG_8345 Large.jpeg
ID:	464460 Click image for larger version
Name:	IMG_8351 Large.jpeg
  • daidensacha
    This is an amazing working (and serving) space! As much an art exhibition as a working WFO Thank you for documenting and sharing this remarkable build with us!
    Thank you. It’s been a joy to build. Challenging at times, but well worth it and I would highly recommend it for anyone who has a passion for pizza. At this point its come down to finishing the details, and I’m looking forward to our first summer being able to use it and enjoy it with our family and friends.
    There were parts of this Neapolitan oven build that I had to really research and consider. David was especially helpful and his generosity in sharing his knowledge and experience was a great support. I wanted to document and share my build process in the hope others might find it helpful.
    I’m grateful that Forno Bravo have been so generous in sharing the plans and this forum as such a great support resource. The oven has far exceeded any expectations I had. I just finished my first 20kg of flour, and as much as I have learned, there is so much more ahead.
  • SableSprings
  • daidensacha
    Granite Worktop Set
    This week we have lovely spring days, 10-14C, with sunshine. My bees are loving it, the first day I see them coming out and orienting themselves for exploration flights.
    The warmer days are great to get back into finishing off details of the oven, that I couldn’t complete with the onset of winter 2024. Today was a big tick, and thinking about how I was going to move the granite was faer worse than just doing it. 120kg top, 2200 x 630 x 30mm. I created a template out of mdf so I could mark and cut one corner out of the top, needed to fit in against the oven. That way I was able to leave the granite laying on the pallet and cut it there with my 125mm grinder and a masonry blade.
    I fitted perfectly, with four of us to move the granite in place, many hands made light work. Really happy with the choice of color too, as it blends with the other colors around it.
Name:	IMG_8336 Large.jpeg
ID:	464434 Click image for larger version
Name:	IMG_8337 Large.jpeg
ID:	464432 Click image for larger version
Name:	IMG_8338 Large.jpeg
    Next step will be to finish the final layer of render on the oven, so I can then paint it again. It will be pretty much finished then.
    Of course, I have more projects planned, and will move into them.
    1. An extension of the upper and lower terraces on the side of the house, with stairs allowing us to come from upstairs down to the rear terrace with the grill and pizza oven.
    2. An oak table. Need to knock up a router sled to level my oak slab, then make some nice oak legs. It will be a nice solid rustic table to enjoy our pizza on.
  • daidensacha
    Ash slab bar fitted
    This week I picked up some 50 x 5 mm stainless flat bar and made some brackets for the top of the wall behind my pizza work bench. I glued some threaded rod in the wall so i could fix the brackets on top of the wall. I wanted the brackets to be flush with the bottom of the Ash slab when it is laid on top. Routered slots for the plates in the bottom of the Ash slab, then screwed through the plates into the bottom of the slab to hold the slab down flat. 5 plates over 3 meters should be strong enough to hold the wood in case it wants to warp with the humidity.
    I cut the end of the slab that fits against the oven dome, leaving a little excess so I can make that custom cut once the final layer of render is on the dome, and it’s painted.
Name:	6584F01C-094B-4183-A4A1-A928A9D2E470 Large.jpeg
ID:	464355 Click image for larger version
Name:	3073CB2F-2AC5-42E1-93F6-B4C796BA969A Large.jpeg
ID:	464357 Click image for larger version
Name:	A67A4CBD-DA5D-4A55-A62D-EF1C707BDC13 Large.jpeg
ID:	464353 Click image for larger version
Name:	97122397-61B4-4DAC-8D53-072C73013258 Large.jpeg
ID:	464354 Click image for larger version
Name:	IMG_8311 Large.jpeg
    I wanted to do it this way to allow the bottom of the slab to breath. It was cut 2 years ago, and has been tried under cover, but still not fully dry. 26%, which I was told with the humidity here is ok under the terrace roof outside. I’m oiling it, screwing it in place and then waiting to see how it fairs with time. If cracks appear, to be honest I don’t mind because epoxy mixed with black iron oxide is a great way to fill them so they become a feature, not a flaw.
  • daidensacha
    Oak slab for table top
    I picked up a nice slab of an old oak tree. 750-800mm wide, 100mm thick, 3500mm long. Got a little bit of work to tidy it up, and a base to build, but it’s a beautiful piece of wood. As a table in the terrace to eat pizza on, it will be amazing. I’ll hit it with a plainer and sander in the next days.
Name:	443A1635-346F-4EED-B320-98AA64B2577F Large.jpeg
    Ash bar has been put through the plainer at the local mill. I removed the bark and cleaned up the sides. Next step is to cut it to fit on the wall behind my food prep bench. It’s a lot lighter than oak, but the nice dark brown heartwood is a feature.
Name:	IMG_8269 Large.jpeg
ID:	464293 Click image for larger version
Name:	IMG_8270 Large.jpeg
