Originally posted by daidensacha
View Post
PS: my gap is 1", fitted with a 1" stainless steel square tube. Stainless steel: low thermal conductivity, doesn't rust in the rain/moisture that it will inevitably see. Aluminium conducts heat very well, so I didn't consider it for a heat break material. As my bricks are around 2", the other 1" was nicely fit with a piece of calcium silicate (1" thick). Thinking about it now I should've filled the tube with vermiculite, as it's large enough to allow circulation to exist inside... but alas...I'm not going to drill a hole in it now to try to get it to flow in.
PS: it would have probably been just fine to put loose vermiculite under your heat break tube, if you close it in from the sides with some tape or cardboard until your bricks are in.
