Re: My indispensible tool (a variation on a FB theme)
jim, sorry I missed your question earlier. you can see my enclosure coming together on my thread. It will be covered in El dorado stone like the arches next to it.
Regards
Greg
Cecilia.....no I did not come up with this idea. Jcg31 started this thread. I suggest you read through this entire thread if you get the chance. I only contributed to this thread for the first time just a week ago.
I just threw in an idea of a slight variation of this tool, which I found out later that it had already been tried and successfully used by another member.
Ok...well, I'm going to read more about them...is this something you invented - is it something that a small brained person like myself can use and understand? Can I purchase it - because I know I could never make it myself!
I hope my remarks are not taken wrong - I am so impressed with how detailed this can get - I start showing people what I'm doing and showing them this website and we can't get off because it's so addicting and interesting...
The mathematics are big hurdles for me, that's all...so is every first step of the next step...if you know what I mean....
CeceliaLeave a comment:
Hi,
There's absolutely nothing wrong with eyeballing, but the tool, like using a form, will help place each brick more accurately than simply eyeballing.
It's not that I think it can't work - I am wondering what happens when you don't use it? Will my oven collapse? I will admit it's because once I start thinking about angles and such, I get nervous - I was a lousy geometry student!
Eyeballing is probably what I was thinking about doing - also making a form.
hmmmm.
This is such a simple guiding tool, how can it not work? I most certainly intend to use it on my build.Leave a comment:
You know, I'm getting so nervous every time I read about someone inventing a tool to put the perfectly cut bricks at exactly the right angles.
How many of you successful oven builders used these tools?
What if I don't?
Anyway, I haven't even started on the dome yet - I need to get out of my kitchen and quit cooking and baking so I can work on the oven!
Nice work, these jigs look awsesome. i just bought a castor wheel and a quick clamp to build my jig with. I had a thought, which has probably been covered already, but if i bring the clamp end in 1/8th of an inch for each course this should bring the top of the dome in flatter. I will probably stick to a true half sphere but just an idea.Leave a comment:
fxpose,
You are correct in that for a flatter roof, the angle does change slightly with each course. If a hemispherical dome is built, there's no need to change it - the right angle holder is correct. But, in doing an ellipse, I just measured and shimmed for the correct angle and let the holder support the brick in the vertical plane, instead of clamping it tight to the inside of the bracket.Leave a comment:
That's fantastic! That's the jig I'll use.fxpose,
Indeed, another builder has used that variation just recently:
http://www.fornobravo.com/forum/f8/c...oven-7630.html
fxpose,
http://www.fornobravo.com/forum/f8/c...oven-7630.htmlLeave a comment:
You would get two intersecting arcs, and if carried to it's conclusion it would dimple down in the center, not that there's anything wrong with that. A builder recently did a rounded rectangle oven that had a flat on top. I was sceptical, but it seemed to work. Brick ovens are very forgiving of geometry.
A true eliptical indispensable tool would have two pulleys mounted on the lazy susan, and a sprung arm pivoted in the center with a pulley near the top, the three pulleys would be connected by a loop of cord or line. I think just having a thumb screw length adjustable slide on the arm would do the same thing with less work. After all, you only need to adjust it once for each ring.Leave a comment:
ceiling height
Afer posting my above response (post #50) regarding ceiling height I came up with an idea on another variation of this ingenious indispensible tool. I drew up a couple of crude pencil sketches which perhaps better illustrates this idea. Perhaps someone has already done this or have come up with this idea, I don't know.
Obviously, by looking at the sketch, the ceiling will start to level off once you approach the last couple of courses by following this geometry.2 PhotosLeave a comment:
I can see that, and this might be insignificant, but I think the angle of the brick holder itself needs to be varied each and every time the rod is shortened for each course of bricks. Otherwise, on the courses where adjustments have been made, those courses will come out staggered.Last edited by fxpose; 08-29-2009, 10:50 AM.Leave a comment:
Ahh you are a man of your word and thanks for all the kind words throughout the process. Your oven looks great, what are you doing for a top enclosure?Jim
I finished with the tool and as promised, passed it with all your accesories to a another WFO Builder here in SD. (Eric Prante - eprante). Also passed him my plywood floor template and both arch supports so he got the complete do it yourself kit. Your tool worked great through out and made for a perfect dome. Thanks again.
JimLeave a comment:
