Thanks for the feedback, hoping to find some time this weekend to start stacking blocks!
Hi, may i ask some questions?
did you insulate between oven and arch/vent?
are those fire bricks on the arch and chimney? or standard clay bricks? i want to use clay bricks for decopration here but fire inside? will this work?
here is my build: https://community.fornobravo.com/for...-oven-build-uk
thanks
G’day narcosi
No there is no insulation between the oven and the entrance structure. No thermal break it’s just an old school oven. The entrance is plain brick commons they are heat resistant enough for use outside the oven proper and most importantly have a measure of water resistance.
Fire bricks are definitly not water resistant infact will soak up the water real fast. Chuck one in a bucket of water chuck a common in another. The firebrick will fizz like soda water as it the displaced air is forced out of the brick. The common will just sit there....
Enjoy making your oven
regards DaveMeasure twice
- Likes 1
Hi Dave
I used Hebel like you for my hearth insulation. Like you, I've found that the fire bricks coming to far out is a problem with the rain. The solution I've decided on (that works) is to have an insulated door and an "outer" door to act as a weather shield. I'm working on that outer door now. The temporary "test" one I cobbled together from scrap works well.
Regards,
MarkMy 42" build: https://community.fornobravo.com/for...ld-new-zealand
G’dayOriginally posted by MarkJerling View PostHi Dave
Regards,
Mark
You can get a long way keeping any rain off the hearth but one thing you can’t fight is humidity. Firebricks just soak up moisture from the air. I’ve just come to except that some times your oven will damp regardless of your efforts.
Regards DaveMeasure twice
Yes, you're right. Luckily, we don't usually have super high humidity. But, a friend of mine gave me some good advice: He said I should fire up the oven at least once a month, even of not used in winter so as to help drive out moisture. Our bigger problem is driving rain, i.e. rain with wind which is why I need to keep the rain off my landing.Originally posted by cobblerdave View Post
G’day
Regards DaveMy 42" build: https://community.fornobravo.com/for...ld-new-zealand
G’day
If you fire the oven up to dry it don’t waste the heat. Typically the fire doesn’t burn for more than hour way below pizza temps and saturation and all those other things. But still I hate wasting that heat!
Anything you want to cook put in a baking dish and wrap it around in cooking foil so it’s completely sealed. Put it on a few of those crockery feet they use on pot plants to keep it off the oven floor and leave in in the oven for a few hours. Can’t burn as the oven is cooling off. Typically some meat goggle Greek lamb kleftico.
Here some foccasia just a basic bread dough really but has a cake like consistency. Looks a little pale cause it’s cooked under sealed foil but all’s good. Top with salami tomatoe onion and pop under the grill
Gday
what happened there? Dunno
anyway where was I. Under the grill to toast the toppings. Crumple some feta over the top and Yummly.Measure twice
G’day
woops done it again1 PhotoMeasure twice
