I have been harping lately about where salvage/used fire bricks came from and what process they were used in. Just trying to keep folks safe from bricks involved with bad chemical or heavy metals processes that may have contaminated the bricks.
new build in werribee
Hi Russell
Hadn't thought of that. Might make some enquiries from the guy I purchased this lot from. The hearth tiles are new, only the dome is used firebricks. My last oven I also used, used bricks i bought from Brickie-in Oz, if you remember.
Everyone that has eaten from that oven is still with us!!!!!
but I do get your point and will make some enquiries. They look ok surface wise. Maybe a light sanding before laying would remove any possible contaminants.
That would be stainless steel. Often, a piece of stainless steel square tubing is placed between the main hearth bricks and the bricks covering the area under the outer arch / vent area. Since stainless steel has fairly low thermal conductivity (see below) and since the tubing is filled with air (even lower thermal conductivity), it acts as a thermal break - see the pictures in the linked thread. That is also why SS is a good material for fire tools.Originally posted by zoolander...I noticed in this thread you talked about a piece of "SS"...What is "SS"?...
Thermal conductivity, kCopper 401 Aluminum 205 Brass 109 Iron 70 Carbon Steel 54 Stainless Steel 17 👍 1Comment
Coastal Pizza already answered the SS question. But a good place to look for a piece of stainless steel tubing is a metal surplus or fab shop for cut offs. The thinner wall the better, you could even use channel as well. You only need a couple feet.👍 1Comment
I would check your local classifieds or Craigslist for used double all SS vent. If you go retail then most big box stores, ie HD or Menards carry it. I have also seen some on Ebay or online stores.Comment
Got too here before April. Then needed to plan a Buddhist commitment ceremony and then plan a Christian wedding, then actually get married. Been with this amazing woman for 10 years.
Will post other photos leading up to this in due course. few other things to do before I can get any further. plus weather has been very wet, and work busy, and weekends have been taken up with family stuff.
The 2 blocks sitting on top at the front will be the final hearth height. The base will store 2 metres of wood as it is 2200x2100 with 4 storage areas. The right side will have a prep area and the oven positioned to the left of the base. Those of you familiar with the last build will notice I'm continuing the Zen Japanese theme.
Cheers3 PhotosLast edited by oasiscdm; 07-14-2019, 06:57 AM.👍 1Comment
Here are the photo's of the property and what I had to contend with to begin with. The Yucca was over 5m tall. Leveled to a foot from ground. Stump was 2m x 1.2m6 PhotosComment
Photos loaded show the setting with all the forest removed, excavated, crushed rock spread. The Yucca root mass gone [thank God]. Now the fun begins, with all the infrastructure stuff and oven base, garden beds, irrigation, pipes under paving water pipes, electrical wiring needs to be installed, pond installed, pump, Shishi Odoshi etc. Will be hooking all of outside to voice control [Echo Alexa].
Let the fun begin5 PhotosLast edited by oasiscdm; 07-15-2019, 12:13 AM.Comment
Hi Again
The base now poured and setting slowly in the hot sun.6 PhotosLast edited by oasiscdm; 07-15-2019, 12:26 AM.Comment
OK
Let's work out how this is going to work.... Just like Lego, I love Hebel.
Aim to maximise storage as I have nowhere to store any wood. So it needs to go in here.5 PhotosComment
Now to join the Lego together. lets start moving up.5 PhotosLast edited by oasiscdm; 07-15-2019, 03:49 AM.Comment
getting higher damn run out of lego. Have to go and get more lego. Arrrrrgggggghhhh5 PhotosLast edited by oasiscdm; 07-15-2019, 03:59 AM.Comment
Ok done. next step render and finish the base. Not sure when i will get back to it. Next 5 months are really hectic.
The centre row of Hebel on the base supports the middle of the oven hearth. Before table top is placed i will run and angle iron lintel across the openings to support the table/hearth.
The table base will be 75mm hebel panel/75mm insulation tiles/25mm calsil board/75mm x 600 x 300 fire brick tiles4 PhotosLast edited by oasiscdm; 07-15-2019, 04:25 AM.👍 2Comment
Looking nice Colin. I am sure build two will be a work of art too.Comment
Hi Colin,
As Hebel is so water absorbent it would be prudent to seal the top of the Hebel supporting slab to prevent rising damp. Get the Hebel Power Panel, it has 4mm reinforcing rods cast into the centre.
Looking forward to your new build.Last edited by david s; 07-15-2019, 02:31 PM.Kindled with zeal and fired with passion.Comment
