Complete oven
  • #16
    Thanks. I've got space around the entire oven, so all good with that. And I've conceded to rock wool for convenience and finance. I've looked a lot at gregs build and I guess I'll be ripping a lot from that. I'm just hoping that a 1560 stand will fit a 965 wfo on it
    • #17
      buddy, im looking at making my stand a little small and putting a lintel on it... maybe you could make the hearth a little bigger that way (since you have the room) to be sure?
      Cheers
      Greg
      My Build: https://community.fornobravo.com/for...erra-australia
      Photo Album: https://photos.google.com/album/AF1Q...JZX8QMLT_9mVj7
      • #18
        I've decided to add a 1/2 block to the foundation to give me some more space. I'll try to put up my plan so far ....feedback would be appreciated
        • #19
          I've got the foundation done. Up to framing for the slab....I,'m not sure where to start on this
          • #20
            I found the PDF info from the Melbourne Fire Brick Company useful - I am sure something it contains would be for you as well
            Cheers,
            Steady
            http://www.fornobravo.com/forum/f51/...ild-21760.html
            • #21
              slab done....now to start some brick work....
              • #22
                I think I'm ready to start the dome and arch
                • #23
                  Looks like you are on your way. Just confirming that you are planning on building the dome on top of the floor and not around the floor so the dome is isolated from the concrete hearth, which would be a heat sink. The entry is fairly deep, which is fine if that is what you want, but it may restrict access to some parts of the oven or require longer tools.I am partial to corner builds.......
                  • #24
                    Ah...the ol' heat sink. I never thought of that...the dome is going around the floor, maybe a little insulation before the first course. Would the fire brick not be enough insulation? as the first course will sit below the oven floor. Thanks
                    • #25
                      So I've made a start...first time I've layed (laid?) A brick. It shows. All the brick cutting is done with a grinder...and that shows too...but I'm hoping it won't fall down. Any suggestions /criticism would be appreciated Click image for larger version
                      • #26
                        A few pics on the progress Click image for larger version
                        • #27
ID:	396866Click image for larger version
ID:	396867Click image for larger version
ID:	396868 having a little trouble putting pics up...but this is where I'm at
                          • #28
                            I'm excited to see you use those curved bricks! I think you are on the right track pb, and it looks good too.
                            Lee B.
                            DFW area, Texas, USA
                            • #29
ID:	396912 next course should clear the arch Click image for larger version
                              • #30
                                looking good
                                Cheers,
                                Steady
