Re: My Wood fired Redux
Thanks.
I usually don't leave the door on while there is an active fire, and if I do, it's in the vent area, acting as a damper. I don't know if you caught this, but the panel is insulated...it's almost 2" wide, and filled with mineral wool. If there is a need, I'll fill the air space between the metal and the wood with more insulation, then cover the gap with a strip of stainless.
The ring is more than sufficient...that's no cheap hardware store accessory. The post is about 3/4" ( 1.94 cm or 19.05 mm, take your pick) 3" long (7.62 cm) hand forged goodness, and is tightly fixed into two layers of wood.. I don't find the door heavy, but I am used to lifting stone, so it's perspective. The door won't hang by only the ring when lifting anyway, I don't have a cavernous vent area...I more or less slide the door out.
Originally posted by david s
View Post
