Wood Fired Beehive in Utah
  • mikku
    • Jan 2013
    • 619
    #451
    Re: Wood Fired Beehive in Utah
    Glad to see you have the weather with you and can start. Looking at the texture of your pericrete, to me it looks a bit dry. I add enough water just to the point when you squeeze it, no water comes out. You should be able to form it into a ball by squeezing and it should retain its shape. Right now, it probably feels really crumbly to you. A sample I made and put into a plastic bag later was also crumbly when the cement set, but the wetter stuff when squeezed into a ball formed a hard ball when set.
    That is just my observation on a "one-time build", others may have some other ideas. Your oven will take on a whole new appearance with this newest covering!
      • 5260
      #452
      Thanks for the info, will try your idea. One batch, seems a little crumbly the other side had a little more water and seems to set better. I'm going to let sit overnight and see what happens.
      • mrchipster
        • Apr 2010
        • 1502
        #453
        Nice start, i like the shaping tool.
        i plan on visiting sometime soon I should be out to SLC sometime early summer and will give you a heads up should it fit into your schedule.
        Was hoping for some spring skiing but went to Palm Springs to get some sun instead.
        Chip
        Chip
          Originally posted by Bookemdanno
          Lookin' good Utah!!!
          Double what he said .
          And the "maters" are coming along great!!
            • 5260
            #455
            Made some headway on the Pcrete. Just as I am getting the hang of forming Pcrete I am getting close to being done.
              That's because the most of the vertical is done! Every layer now is going more horizontal . It gets a "helluvalot" easier from here. Great job!
              • dvm
                • Mar 2012
                • 242
                #457
                Think how much easier it will be next time.... wait never mind - don't think of that.
                dvm
                sigpic
                • mikku
                  • Jan 2013
                  • 619
                  #458
                  Lookin great--it's a keeper!
                  • fabby
                    • Jan 2013
                    • 111
                    #459
                    that build is looking great.
                    Have you had much shrinkage on the prericrete? What was the final thickness you went for?
                    I am having trouble finding the ceramic blankets and I am thinking about just using vermiculite, which is readily available around here.
                    Oh, how much will you end up using?
                      • 5260
                      #460
                      Thanks guys,
                      Fabby, I have not seen any shrinkage as of yet, using a 5:1 mix because I already have CF underneath and I want a more solid base to render to since I am cladding my dome with copper and screwing the shingle to the dome. Average thickness is 2-3", you may have to double your vcrete thickness to get an equivalent insulation value of a CF blanket. If the mamma does not get her way with the dome, you could just pour the vermiculite (w/o portland) right over your dome in the enclosure. I am into my 3rd 4 cu ft bag, bought 4 but don't think I will need it. Running about 9-10 bucks a bag at a concrete block supplier.
                        • 5260
                        #461
                        Finished percrete today, going to let it set for a week or so to dry out before I render. All said and done the curved trowel was the key tool to keeping the shape. Ended up using 3.5 - 4 cu ft bags roughly 2-3" thick 5:1 ratio. Used a beer bottle as a blockout for the vent in the apex of the dome.
                        • deejayoh
                          • Jul 2010
                          • 1893
                          #462
                          Glad to see you drank the beer first
                          My build progress
                          My WFO Journal on Facebook
                            Excellent work on the pecrete!
                            And a great choice for keeping with what I think will become an "industry standard size" vent opening .
                              • 5260
                              #464
                              Just got back from Cabo for a little R and R. Good part the perlcrete on the oven could sit and dry for a week. The bad part, what do they say about drinking the water , so the party I planned for tomorrow is off until the SWMBO and I recover.
                              But a WFO in any language is a WFO. Here is one in a small village called Pescadero. They were cooking pies in about 4-5 minutes and chicken in a skillet at the same time.
                              • deejayoh
                                • Jul 2010
                                • 1893
                                #465
                                Hey! I was just down in Todos Santos for 3 weeks. Where were you staying?
                                My build progress
