Re: K79 Oven Build
sorry it looks like perhaps I misunderstood your measurements....
Not sure what you mean by vent landing? You mean the flat bit that the SS chimney vent plate sits on? If your opening is 41 sq in and you are doing your best to taper into the 7" diameter hole then I think you will be good.
Neil
Re: K79 Oven Build
Originally posted by boerwarrior View PostHi K79,
well as you know I am still working from theory....! But I am planning to ensure that my opening is larger in terms of area than my chimney... I have a 6 inch diameter chimney pipe (28 square inches) - and I plan to make the vent opening 5"x 8" (40 square inches) to ensure that nothing is being restricted until the smoke/air hits the chimney vent cap.
I would be interested myself in reading other responses from experienced builders/users!
Neil
Re: K79 Oven Build
Hi K79,
Neil
Re: K79 Oven Build
Ok final dimensions for my vent:
(Using a 4' x 7" ss double wall chimney)
Oven opening: 200 sqin
15% of oven opening: 30 sqin
7" Diameter Chimney: 38.48 sqin
Vent opening unobstructed by inner arch, outer arch, and anchor plate for chimney: 34sqin.
How do these numbers look to you guys...?
Re: K79 Oven Build
Originally posted by boerwarrior View PostI did my last 3 rows and keystone all on the same day. Been curing a little over a week and no cracking yet - I'm sure that will change once I start firing!
Neil
Re: K79 Oven Build
Neil
Re: K79 Oven Build
I have 4 rings left. I'm hoping to be down to my last two by the weekend. Question: My last two rings consist of 13 and 10 bricks (on paper) so is it ok to put in my 13 ring layer and then put my 10 brick layer in right after or should I wait a day and let the mortar set on the previous layer? Same question for my keystone.
thanks
Re: K79 Oven Build
I see your tapered arch paid off dividends.............worth the brain work out?
Re: K79 Oven Build
Fish hook and weight is a great idea.
Nice top of the arch brickwork. I wish mine looked that good. Another fine example of the benefits of the reaching arch design.
Chip
Re: K79 Oven Build
year you were born??? ouch!
do a single pointed brick laying vertical and adjust height and angles to mate with the brick height on either side of this transition brick.
Re: K79 Oven Build
That would do it. Could also do a single pointy brick in the middle, figuring that the next brick over the arch is going to be funky anyway.
