Originally posted by Tscarborough
View Post
Re: K79 Oven Build
Re: K79 Oven Build
79, you're going to find that as you go higher in the courses you're going to start to see "V"s from the prior course. I mention this now because you need to understand that unless you cut and place and mix a coffee cup of mortar at a time you are going to have to accept the mortar joints are not as tight as you might have dreamed that you wanted or needed.
From time to time it's important to remember.
1- Cracks are to be expected.
2 - Insight comes with experience and most of us start with no personal experience.
3 - A dome built with half bricks and a dump truck of mortar still cooks incredible pizza.
4 - Insulation is a minor part of the cost of the build, even the expensive insulation.
5 - A dry dome is a happy dome
6 - Someone around here has done what you're doing
7 - Your back will get tired.
8 - Opinions are like ..., everyone has one.
Chris
Re: K79 Oven Build
Yes, when pre-cutting, always leave the last 2 brick until the rest of the course are in as you will be cutting them again anyway.
If you insist on using that mortar, you will need to add some fine to medium grit sand to keep it from shrinking in joints larger than 1/4". What you have laid is fine, but as you go up the dome, you will begin to get 3/8" to 1/2" joints on the face and even larger ones on the back side.
I used that type on my barrel vault, but I was able to keep the joints thin on the face and fill in the back with a different mortar. Again, I don't recommend it's use for a Pompeii oven.
Re: K79 Oven Build
Believe me it is a compliment to be compared to Les, his is almost a mortarless build. You will most likely encounter what I call for a lack of a better term, mortar creep. You will most likely have to make adjustments. Do them near the front end not the back half. You will never see them that way after the dome is complete unless you stick your head inside. Nice looking start......Last edited by UtahBeehiver; 04-29-2013, 07:32 PM.
Re: K79 Oven Build
Originally posted by Tscarborough View PostKbartman, you really do not want to use that refractory cement on your build. It is made for MAXIMUM joint width of 1/4". It is also water soluble, so wetting it is not doing any good. It is a heat-set mortar.
For Heatstop, mix no more than you will use in 10-15 minutes. Slowly add water until is a tad wetter than peanut butter. Once it begins to set, you can re-temper it once (remix it), but after that throw away any left and mix a new batch. It does not need to be kept moist to cure.Originally posted by K79 View Postthanks kbartman. I'm using Heat Stop for my high heat mortar. No instructions on the bag. I'm going to try and give them a call. What is the normal procedure? You need to spray the mortar until it cures? Roughly how long is that? I'm planning to cover my dome while not working on it with a tarp?Originally posted by K79 View PostCan you please explain the re-temper procedure? Basically at around the 10-15 minute mark if it starts to change consistency I can mix it and it'll be good for about another 10 minutes?
K 79 your oven is looking good.2 Photos
Re: K79 Oven Build
Originally posted by SCChris View Post79 the bricks look like you want to dry stack the oven and I fear you're going to find that mortar isn't as thin in the joints as you anticipate. Plan for trimming a brick or two to fit your rings.. Are you planning a "Les" style" oven where you only mortar the back of the bricks?
Chris
Re: K79 Oven Build
Chris
Re: K79 Oven Build
They look very precise...hurry up and start mudding them in already.
Re: K79 Oven Build
Originally posted by K79 View PostCan you please explain the re-temper procedure?Last edited by stonecutter; 04-29-2013, 05:31 PM.
Re: K79 Oven Build
Not knowing what either looks like, what are the functional differences? What are the aesthetic differences?
After knowing these, make a decision and live by it..
No guts, no glory!
Chris
Re: K79 Oven Build
I can't believe I'm about to say this but I'm not sure now if I want to do the arch entry like Kbartman or the style with the stright sides like Ken524's oven. Advantages/disadvantages of each? Supposed to be starting my brickwork tomorrow
my name should be Indecisive79
Re: K79 Oven Build
I don't see any issue with leaving the template, without oxygen it'll just carbonize. I would take off any excess you have access to afterward.
Chris
Re: K79 Oven Build
Anyone see any issues with me leaving a paper stencil between my insulation board and my oven floor? I have a stencil made on my plotter and would like to lay that on my insulation board and lay my brick on it so I can check all of my cuts and fit them as I go. Only issue... no removing it once the brick is in place.
Re: K79 Oven Build
