Re: My 40" Inch pizza oven in Florida
Thanks Colin,
Although I won't call it perfection, far from it.........
.....................Anyway appreciate the confidence...........Arches complete...Decided to change from brick to brick pavers to accent the base,..........I think I like how it turned out.....least wife is happy, that's half the battle...........I hope I have cut my last brick ......Yippie
........Just one more,to lay, it will go in front of my pool light j-box. I hope it will conceal it nicely. I plan to cover the last base brick paver in plastic wrap and mortar in place. After it has set up, remove the brick and plastic then replace. I hoping any gap between the brick and the set up mortar can be hidden with cement only paste. If access is needed later, a slight taping would free the brick. I think
..........Does that sound workable? Comments and suggestion needed.
Thanks Colin,
a least mine anyhow.
. Thanks for you rsupport I value your opinion.
. A good paint job is my only hope. I used this high temp caulk for the heat break. seems to be holding up well.
