K79 Oven Build
  • Re: K79 Oven Build
    Ok, I'm wondering if I should cut out a ledge on my outer brick wall Option 1.
    Or if I should just butt my arch right against my wall Option 2 (right side option)
    text is cut off because my photo is too big.
    Any thoughts?
    Link to my oven build on YouTube:
    http://www.youtube.com/watch?v=Ujb7lqVcSzQ
      Hi K79
      are you thinking that one of these options will be structurally better? I'm no structural engineer (actually I am am electrical engineer!) but they both looks similar to me in terms of structural support. In which case I would go with the simpler design!
      Question back to you - I am also thinking of buttressing my outer arch - are you worried about heat loss through the firebrick and angle iron? I was thinking about using some leftover CalSil insulation board to place between the arch support bricks and the buttress (which in my case might be red brick)
      Thanks!
      Neil
        I've never worked with brick so I'm a little uncertain of these sorts of things. I like the idea of that little ledge but I don't think it is necessary.
        The buttress is very important for our arch design and no I'm not worried at all about that little bit of steel up against my outer arch wall.
        ughh electrical engineering haha never caught on for me... a few books of my shelf:
          My design for my outer arch:
            That looks good, K79! It's pretty much exactly what I am going to do - with the exception of flattening the keystone brick and the two adjacent ones. If I'm lucky and I complete mine this weekend I will post photos!
            Neil
              Neil
              Good deal I can't wait to see it! All of the bricks in my outer arch are 1/2" higher than my inner arch to make my reveal for my oven entrance. To make a nice flat surface for my anchor plate to sit on I need to flatten the middle 3 bricks or raise the back arch by 1/2" or so.
                I'm going to do exactly the same thing - raise my outer arch by 1 inch to allow for the reveal. But I will use some "spacer" bricks to flatten the top for the chimney vent plate.
                Does the "79" in your user name indicates something? Is it 1979 and is this a significant date for you? (It is the year I graduated high school!)
                Neil
                  Neil
                  It's the year I was born
                    Ok so hopefully my last issue before I finish my dome... (major in my mind):
                    I think I have the dreaded drop or taper by my arch. When I go to bring my bricks into my arch from my ring with my IT the following pics show what occurs:
                    This pic shows that my dome arch and rear of my ring is level...mostly that's a good thing:
                    This is a pic of what my brick looks like when broght into my arch... (How Do I Fill This GAP !!!) Can I just make a triangle wedge??
                    This illustrates what I believe is the dreaded drop or taper:
                      I ran into that on my build, and just on that side of the arch, too. What I did is I cut the corners off of a brick turned on its side. So, start with a 1/3 brick, turned to be 3" H x 2.5" W x 4.5" D. Then cut the inside bottom corners until it makes a point that fits into your gap, with the top sitting flush with the neighboring bricks in the next ring.
                      You can see my kludgy fix just to the left of the really short bricks above the arch in this picture:
                      My build: http://www.fornobravo.com/forum/f8/3...-dc-18213.html
                        Ok, so instead of filling it with a brick wedge or high heat mortar you put in 1/3 of a brick on it's side. I follow. So I'd have about 2 or 3 bricks stacked like that to cover my gap area. My mortar joint for some of these might line up with my joints below. I'll be considering this option thanks. Any other ideas???
                        So cut two bricks to fit like the picture below?:
                          That would do it. Could also do a single pointy brick in the middle, figuring that the next brick over the arch is going to be funky anyway.
                            If I did that then my brick would be lower than each adjacent brick:
                              year you were born??? ouch!
                              do a single pointed brick laying vertical and adjust height and angles to mate with the brick height on either side of this transition brick.
                                This is what ended up going in. I just had a chance to check the forum since I last posted.
                                Also this is my idea of holding my bricks in place once I get closer to the top:
                                Fishing hook tied to one of my socks with a brick in it for weight
