My 40" Inch pizza oven in Florida
  • Cheesesteak
    • Mar 2011
    • 192
    #181
    Re: My 40" Inch pizza oven in Florida
    Originally posted by kbartman
    After working night shift the last few days, I did some inspections on the courses that already lay. I have been trying to keep the mortar moist as possible with spray bottle and water hose. The suppliers ask me if I understand the Demon mix was for tight joints under 1\4". Understood but thought I might get away with the joints between the courses being a little larger. I?m now not so sure.
    Attached are some pics of the curing I think I will use the bevel scraps between the following courses any suggestions is appreciated.
    The sides of the oven that get morning and afternoon sun shows signs of premature curing
    Ps. The dreded Lovebug season has began.
    Looks like you might be past this part - but I put a wet towel over the oven when I took my break for the day to keep everything moist. if you're still having issues keeping moisture in - you can put a damp towel and then cover with plastic or a tarp.
    • kbartman
      • Feb 2013
      • 572
      #182
      One more course. Slow going today modified arch support and laid one course...................Slowly but surely.
      Respectfully,
      KB
      My build
        • 5264
        #183
        Slow but nice brick work and good job keeping the joints staggered.
        • kbartman
          • Feb 2013
          • 572
          #184
          Fifth course up and coming. Better control of the mortar joints. I never knew 1 or 2 degrees would make such a big difference. I will pay more attention from here on out.
          Put the lady to bed for curing till I have more time to continue. I will be pondering thermal breaks and the outer arch. Should I set the arch directly on the concrete hearth or on the floor insulation?
          Respectfully,
          KB
          My build
          • brickie in oz
            • 3445
            #185
            If you are having a thermal break then you can set it right on the concrete, if no thermal break the you will need the insulation.
            • kbartman
              • Feb 2013
              • 572
              #186
              Thanks,
              Cheesesteak damp wet towel is working good to retain moisture.
              Thanks,
              Brickie I will be doing a thermal break not sure what type yet. I'm thinking Insulation in the oven landing and thermal break. My thoughts are of grilling by raking hot coals into the landing under the flue would be the best place to grill and not bake the food by grilling inside the oven.
              Thanks all, for all the great comments and suggestions.
              Originally posted by K79
              looking good ...
              Originally posted by Tscarborough
              Keystones are for looks more than anything else.
              Originally posted by V-wiz
              That may change once you get mortar in there.
              Keep posting,
              KB
              Respectfully,
              KB
              My build
              • kbartman
                • Feb 2013
                • 572
                #187
                Made a little progress yesterday.......My idea of tying inner arch to the dome and staggering joints did'nt work as well is planned. The further up proved next to impossible.
                K79,
                My concern on my build and yours as well as other builds is the joint between the inner arch and dome bricks. The one solid joint seems like a single point of failure. Here are my 2 cents and thoughts. Attached is a picture of the inner arch to dome transition of my build. I hope I did the right thing. I staggered the joint after the first straight up soldier courses. I?m thinking I should have started sooner but it is as it is. The staggering of the joints will become more difficult as the arc of the dome grows with the coming courses. Although the inner arch will begin to support the dome wall and become less of a vertical joint.
                As in most block construction the corners joints are staggered and the walls do not just butt up against one another. I would like to know what you and others thoughts are on this. I hope I made a good decision.
                Attached is the outcome,I settled for tighter joints verses staggering
                Respectfully,
                KB
                My build
                • stonecutter
                  • Jun 2007
                  • 2003
                  #188
                  You don't need to stagger them anyway. The dome is going to move and that line will act as an expansion joint, which will protect your arch from movement better than if you tied into the dome.
                  Old World Stone & Garden
                  John Ruskin
                  • kbartman
                    • Feb 2013
                    • 572
                    #189
                    Are you saying at this point, I should take a hammer to it? I sure would hate to do that, But if a expansion joint is needed, it needed.
                    Respectfully,
                    KB
                    My build
                    • stonecutter
                      • Jun 2007
                      • 2003
                      #190
                      No, im saying that staggering the joints wasn't necessary
                      John Ruskin
                      • K79
                        • Nov 2012
                        • 391
                        #191
                        Looking good !
                        Link to my oven build on YouTube:
                        http://www.youtube.com/watch?v=Ujb7lqVcSzQ
                        • kbartman
                          • Feb 2013
                          • 572
                          #192
                          Finalized 6th course today......???.. I now have more respect to those whom have trodden before??? My hat is off to them??.. It not as easy as it looks ??????.. The upper courses I?m sure will prove even more difficult.
                          Having to work on both side of the wall is giving me a work out. My laziness has cost me a few mistake by not walking all the way around to have a look.
                          Respectfully,
                          KB
                          My build
                          • boerwarrior
                            • Apr 2013
                            • 454
                            #193
                            looking great, KB! You have a very nice transition going there! Looks to me like you have most of the hard stuff behind you
                            Neil
                            • Bec1208
                              • Nov 2012
                              • 416
                              #194
                              Looks great to me. I'm getting stuck trying to set jig for first course with a vertical tilt. About to post about this on my thread. Appreciate any help. Bruce
                              Link to my build here:
                              http://www.fornobravo.com/forum/f6/3...lly-19181.html
                              Selected pictures of the build.
                              https://picasaweb.google.com/1168565...g&noredirect=1
                              sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
                              • K79
                                • Nov 2012
                                • 391
                                #195
                                Hey Kbartman it doesn't appear that you have needed any sort of form yet for laying your rings. What are you plans when you approach the top of your dome?
