Re: My 40" Inch pizza oven in Florida
Looks like you might be past this part - but I put a wet towel over the oven when I took my break for the day to keep everything moist. if you're still having issues keeping moisture in - you can put a damp towel and then cover with plastic or a tarp.
Slow going today modified arch support and laid one course...................Slowly but surely.
. Should I set the arch directly on the concrete hearth or on the floor insulation?
I sure would hate to do that, But if a expansion joint is needed, it needed.
