Randy's dreams do come true oven build
  • DavidApp
    • Sep 2012
    • 348
    #61
    Re: Randy's dreams do come true oven build
    Hello Randy
    I do not know about the vermicreete squishing out but the edge is fragile so it need some protection during the build as does the Fiber board. I cast 2 vermicreete blocks to go under my entryway pillars. I found that they were about 1/4" too high and I had to use the angle grinder to cut them down to size. I used a 5:1 ratio and cast them in a wooden form.
    I gather that the fiber board has a higher insulation value than vermicreete.
    David
      Steve,
      Yes, the lazy susan does have a lot of potential. I have built several from scratch, and installed a couple of kits. But, all have been in kitchen cabinet corners or island bars. They help turn a hard to reach area into a very handy space. I have been giving that idea a little more than a casual thought. Though, it would be much easier to build it in to the origional stand construction, one could be retrofitted. Octagan or round, either would be more space efficient, than the drawer style that I built.
      Randy,
      I have only noted one builder relating to vermiculite "squishing out" if it is not properly contained. Though many, including myself, have advised to protect it's brittle corners during the build. And, it is commonly accepted that two inches of ceramic fiber board or calcium silicate are equal to about four inches of V or P crete. If time is a factor and money is not, doubling the board is fine. I did not coin the term but, there is a point of "diminishing returns" when it comes to insulation. If money is a factor, you may not get all that much more performance out of two layers of 2" board insulation, than two layers of 1?” board insulation.
      just sayin
      Joe
      • RandyJ
        • May 2010
        • 1191
        #63
        Hey Joe thanks for the response. I am sure there is not much to worry about on the squish factor. I sometimes pick obscure things to worry about. I also know that I will be going into the zone of diminishing returns. That is fine with me. I want to make sure that I will have good heat retention. So I think I am going to do the 4" of ceramic board insulation. I do have time constraints. As I have a 9 month old son and I don't want to miss out on him growing up. So if I can cut out a few weeks for $100 dollars then I feel that is a good trade. And will be well insulated.
        As for the lazy Susan I am going to do some more thinking about that. I can definitely see the advantages of it. So I need to try to figure out what all I want to keep out at the oven and just how to store things to make sure that everything does not get affected by the weather.
        Randy
        • DavidApp
          • Sep 2012
          • 348
          #64
          Hello Randy
          Remember that if you go with 4" of Fiber board instead of 2" Fiber board and 4" of vermiculite your hearth will be lower.
          David
          • RandyJ
            • May 2010
            • 1191
            #65
            Good point David. How high is yours?I am figuring that mine will be about 42.5" to the oven floor do I need to did another inch or two if I go this route?
            Randy
            • DavidApp
              • Sep 2012
              • 348
              #66
              Hello Randy
              My hearth is 43 1/2" and I find that a good height to work for me. I am 5' 9" but I do find that I have to duck down or step back a bit to see to the back of the oven as the entry arch obstructs my view. The entry way arch is 57"at the center. The entry way comes to within 5 1/2" of the front of my stand so that has a bearing on my view.
              I agonized over the height for some time, In fact I bought some 1/2 blocks to use for the stand but I thought that would have been too much. I ended up with 4 blocks, 1/2" mortar joints and spacing the slab up about an inch.
              Hope that is some help.
              David
              • RandyJ
                • May 2010
                • 1191
                #67
                Hi David are you saying that the cooking floor is at 43.5" or your slab top is that high? I could always just get some of the 8"x16"x1.5" patio blocks and space up a little and poor an extra inch on the slab to bring it up a little or does that sound like a bad idea. I need to get some real numbers as I just dry stacked my bas and core filled it. Just got it done yesterday.
                Randy
                • DavidApp
                  • Sep 2012
                  • 348
                  #68
                  Hello Randy
                  My cooking floor is at 43.5"
                  The 8" x 16" x 1.5" sound fine.
                  I did tie my base to the slab with rebar but that is probable overkill.
                  I have a pork shoulder cooking at the moment. A pity it is not possible to share the smells as the oven is opened. It is not like opening a regular kitchen oven.
                  David
                  • RandyJ
                    • May 2010
                    • 1191
                    #69
                    Yes I wish we could send smells and maby samples through the net that would be great. Yes I too tied my base in to the slab with rebar. I figured it would not hurt. I feel bad for who ever decides to tear it out in the future. It will be pretty tough with all the rebar. I will shoot for around 44 to 45 inch hight on the cooking floor. I am 5' 11" tall so that should be about right I think.
                    Randy
                    • mrchipster
                      • Apr 2010
                      • 1502
                      #70
                      Randy
                      Same here I think I could use the area under the oven as a tornado or bomb shelter should the need arise. And if someone wants something else where the oven is (in the future of course) they may need a bobcat mounted jack hammer to break it up.
                      Chip
                        Randy,
                        This is my two cents. After adjusting for inflation, I know that is not very much . The older that you get, or the more hours that you spend in front of the oven, the more you will appreciate an "Ergonomic" heighth for your oven floor. Mine is a little higher than elbow heighth.
                        Get some cardboard boxes, do a mockup, (of your intended floor heighth and arch opening) and test for yourself what is your "ergonomic heighth".
                        just sayin
                          My dog is very smart. Or at least as afraid of the weather as I am. When it thundered, that is where he went. Until, I enclosed the wood storage .
                          • RandyJ
                            • May 2010
                            • 1191
                            #73
                            Well I got a few more hours today to work on my base. I got my form for my arch done and installed. I also got my supports and cement board put in place. I also got the form boards for the slab in place as well, but it was to dark to get a picture. My slab is going to be 5" thick to help make up for the fact I dry stacked my block and I am sitting a little low. If I add a 8x16x1.5 then I will be about 43.5" to my cooking floor. I now need to get to bed as I volunteered to work a shutdown tomarrow after I work all day. Nothing says tired like a 16hr day. But I will have Wednesday off so I am hoping to get my slab poored then. I just need to get my rebar in then to be ready.
                            Randy
                            • sharptailhunter
                              • Dec 2011
                              • 102
                              #74
                              Looking good, Randy!
                              I poured my lintels, albeit not arched, like you're doing. Yours will look great, no doubt! I would recommend using some sort of release agent on your forms. I used some liquid wrench silicone spray. It worked well. I've read where people have used vegetable oil, armor all, or WD-40. I think anything like that will work. I'd also drop some vertical rebar pieces into either side of your arch, maybe even some arched pieces that go up, over, and back down your arch. Finally, I've found that using an old orbital sander to vibrate the wood forms helps the concrete to settle into the voids and helps to avoid the honeycomb effect. Perhaps you already know all that?? ��
                              I'm excited to see how it turns out!
                              • Greenman
                                • Feb 2013
                                • 1123
                                #75
                                That looks like a lot of good work Randy. I might be missing a detail but how are you going to remove the inner mould of your arch on the base. It looks like it might be entrapped by the pour.
                                I hope you can tell me that I am wrong and you have it under control.
                                Cheers ......... Steve
