Originally posted by david s
View Post
Does the castable refractory require firing to set?
It raises a question I have about two different types of fire cement/ mortar available here in Germany.
1. Hydraulic binding mortar. Binding/ setting process is chemically triggered with addition of water. Has 30% clay,
2. Ceramic binding mortar. Binding is made through firing at temperatures of around 800C.
I’ve used hydraulic binding cement, and gotten used to it. The bricks need to be wet, and once cement added I need to put it exactly in place within seconds of contact as the water is sucked out as soon as two bricks are in contact.
Ceramic binding mortar was sent by mistake in my last order and I laid a course using it. It was totally different in consistency, a dream to work with. Stays creamy even after bricks are together, and allows for easy adjustments once they are. Can add brick wedges in gaps very easily. I removed the course and mortar as I wanted to complete the oven using the hydraulic setting mortar. I was unsure how, and if the ceramic binding mortar would set with temperatures reached in the oven.
Do you know if it’s possible to use ceramic setting mortar on an oven dome? It would make life much easier fitting the bricks.
