  • Giovanni Rossi
    • Mar 2021
    • 310
    #91
    This exchange reminded me of a post I made about a year ago...
    This is when I like to remind new builders of the wealth of information on the Forum. All builds are unique, but there are certain "rules" and techniques that pertain to most of the projects. A little time spent researching a topic can pay dividends down the road by saving both time and money. Members are more than willing to provide answers to direct questions and will offer suggestions if they notice something, but that depends on the right person being on line when you need help. This aspect of a community site is invaluable, but there are ways to exploit the already available information and focus your questions.
    If you're new to the Forum, it's not practical to read hundreds/thousands of posts, but you need to read some to understand the lingo. Once you do, don't underestimate the power of searching the Forum for a particular topic. Granted, sometimes using the built in search function can be challenging, but it can yield good info.
    Another option that works well is a direct web search. If you type the url site:community.fornobravo.com "indispensable tool" or whatever term you need in your web browser, you may get better results. Now, as with any search, the results depend on the people adding the content. In this case, you would miss posts with the misspelling indispensible. Also, the results of one search will lead you to search more focused topics.
    IH123 Thanks for indulging me this public service announcement on your thread.
    Looking forward to following your progress!​
    • JRPizza
      • Jan 2012
      • 1558
      #92
      If you can get your pivot point lowered to match the top of the brick floor it will give you the "most" hemispherical dome. I am not sure you would ever notice if it was higher in the middle by an inch or more but if you can place it optimally without too much trouble, why not? I used a technique I picked up from Gulf I call the "wooden brick" that put my pivot point at a height that made my oven half as high as it's diameter.
      My build thread
      • IH123
        • May 2026
        • 134
        #93
        Thanks for the tip, I have looked through many forum posts however sometimes when someone is undetermined and choose a thing under the pressure of time and design complexity it helps a lot to hear from someone else
        • IH123
          • May 2026
          • 134
          #94
          Thats what I was thinking of doing, I am also making another tool: attached an axle (stick) on two quarter circles glued together side by side (to become thicker as I used 1/8" thick board to get precise cut) and I could insert the stick of them into the centre of the oven (into a drilled hole on hearth brick ( to be replaced by wood brick if cant drill - thanks for the tip),which later I could seal with refractory mortar as its a tiny pin size hole on hearth brick, with this tool the quarter circle rests on actual hearth, I only need to cut from the bottom of the quarter circle board the thickness(height) equivalent to the distance between hearth top surface and actual sphere /dome centre below it , which is in my case about 2" below the hearth -I will post pictures tomorrow when I finish it its being kept clamped to curing the wood glue now.
          I will actually cut the quarter circle board bottom AFTER building the dome's spring/soldier line and hearth, thats because levelling under hearth or dome first course my not be exactly at same level when built and not known exactly now, by then , I can measure the distance between dome's first course brick's bottom and the hearth brick top surface and cut the board as needed so it creates my dome desired height of 14 1/8"
            • 5264
            #95
            If you have the ability to make the IT length adjustable (small increments) it will really aid you when doing the brick work. There are so many variables that can make the course laying wonky, ie mortar gap creep, brick size variations, etc. By having an adjustable length IT you can correct the variations as they come up.
              • 9216
              #96
              A turnbuckle makes a great adjuster.
              • IH123
                • May 2026
                • 134
                #97
                so here is the quarter circle that i made, yet to cut at the bottom 16 1/8- 141/8=2.00", I will however do that closer to when the dome spring line/soldier course and hearth is built so I can adjust the amount based on if the hearth is at same level as soldier course or not. the picture below shows the oven foot print template (to be used to cut insulation) and the dome curve check tool (quarter circle):
                • IH123
                  • May 2026
                  • 134
                  #98
                  I have created the insulation board cuts plan, the best I can think of:
                  • IH123
                    • May 2026
                    • 134
                    #99
                    I will try to dry fit first, I am not sure why do I need to adjust the radius when its a fixed. I have seen others on the forums here use it to draw the arch cuts , however for the dome with fixed radius I am thinking, I should stick to fixed tool, the dome won't be stable if some of the bricks are not on the exact sphere, so I think if I build a brick out of order I have to replace it.
                    • IH123
                      • May 2026
                      • 134
                      #100
                      Thanks, I will try not to use it for the dome though
                        • 9216
                        #101
                        It is useful to have some adjustment because removing it can easily break the mortar bond with the brick tight up against the bracket of the IT. Some builders use some corrugated cardboard there which can slide out with a bit of give to help removal without disturbing the brick mortar bond. You’ll work out a method as you go.
                        • IH123
                          • May 2026
                          • 134
                          #102
                          never thought of this before however 100% valid as brick surface is flat. my trammel however has a screw bolt that when unscrewed from its tight it will have few mm play to allow easy sliding away, the quarter circle tool is even better as its only 1/4" thick.
                          lucky me I am aiming for 1/8" max mortar so that would help is tiny soft tapping should fix the consolidation too.
                          • JRPizza
                            • Jan 2012
                            • 1558
                            #103
                            if you make your IT right, you should be able to lift off of your bricks after placement without pushing them out of place, at least I was able to do it. I know the relationship of the IT "rod" centerline to the center of the brick has been discussed many times (I can't find any right now) if it is not optimum it will make it hard not to dislodge the bricks when disengaging. I think the center of the rod has to be above the center line of the brick or it will push the brick away. I see UtahBeehiver has been commenting on your build, he can probably shed more light on this issue. I am attaching a picture of my brick indexer for reference.
                            My build thread
                            • IH123
                              • May 2026
                              • 134
                              #104
                              yeah, thank you very much for trying to help. I am sure I can sort something out when laying my bricks, the rule is: have the radius correct, and do not shake the brick when removing the tool.
                              • Giovanni Rossi
                                • Mar 2021
                                • 310
                                #105
                                It seems you're all over this, but I'll add this for newer builders:
                                I can't speak academically about IT geometry, but there are a lot of references in the Forum to aligning the pivot point with the center of the brick as JRPizza stated. I believe it's then a matter of properly aligning the face of the bracket that the top of the brick rests against to that radial to allow for easy removal of the IT from the brick.
                                I built from a kit that supplied an IT that was not adjustable. It worked perfectly to create proper alignment of the bricks as well as easy release. The pivot point was not directly over the center point, so it moved in a circle (~4.5 cm dia) around the center point. That just changes the diameter of the dome.
                                As others have said, the height of the pivot point relative to the floor determines the geometry of the dome by altering the equator of the sphere. My IT's pivot point was higher than the floor. That fact was quite apparent in my build because the dome didn't have a decreasing diameter compared to the previous course until the 3rd course.
