My 40" Inch pizza oven in Florida
  • kbartman
    • Feb 2013
    • 572
    #211
    Re: My 40" Inch pizza oven in Florida
    Originally posted by K79
    Check out my thread to see how I'm holding up my brick. Doesn't work well when you dry fit as the bricks want to slip but to hold them in place with some mortar its awesome. Post 300.
    Thanks 79, I have not had any trouble with the mortar holding the bricks. The high heat mortar is pretty sticky. I like the hook idea will probably use it on the upper courses.
    Originally posted by Calisdad
    Nice piece of work kbartman.
    My saw just arrived yesterday so I'm a bit behind you. I like your arch transition and your use of firebrick shims on the dome. I haven't seen anyone else employ clay as an aid either. Good idea.
    Calisdad, welcome aboard look forward to watching your build.
    The arch transition not my idea, I've seen the pictures of the arch transition successes and failures this one seems to me the way to go. Thanks to all those whom have gone before.
    I found that in my cut to fit approach that the mortar was setting up too fast. Clay allowed for me to cut and dry fit the whole course. This allowed me to lay the whole course relatively quick, enough time to allow me to tap around the whole course concentrically while mortar was still workable, allowing better overall alignment. I hope it works on the upper courses.
    The shims are just the scape cuts used to fill the wide mortar joints the Super Demon High heat mortar shrinks a lot.
    Nice work clearing the arch.
    Utah, a compliment from a pro like you mean allot………. Thanks
    Respectfully,
    KB
    My build
    • chirobuggy
      • May 2008
      • 44
      #212
      Originally posted by kbartman
      Chirobuggy's he the man , and he's a only a serf.........Looks like K79 and Boy wonder are going to be pushing his broom...........I promise my next post will be serious
      Thanks for the compliment KB....I was just catching up on your thread ans saw this. Looks like it was from March? I dont know what I did to deserve the complement but Ill take it.
      • kbartman
        • Feb 2013
        • 572
        #213
        Chirobuggy,
        I was just messing around giving all a hard time back then......... You?re still the man after today?s calculation the post to view ratios of our three threads.
        Today stats:
        Chirobuggy.........48 views per post
        Kbartman...........31 views per post
        K79...................23 views per post
        By the looks of your stats and your new IT base we will be pushing a broom for ya. Even though K79 just made it to Journeyman status and I'm only a Apprentice. .......LOL
        Glad to have ya back look forward to watching your progress.
        Respectfully,
        KB
        My build
        • chirobuggy
          • May 2008
          • 44
          #214
          Okay! now I get it I didn't even know you could look at that stuff but it makes perfect sense now! Surprising though...
          I just hope my build looks as good or at least somewhere as good as all that are mentioned. Its great to be able to learn so much from everyone on the site. Just wished I had more time to keep up with you guys. I might be able to catch up now that I'm going all in.
          • kbartman
            • Feb 2013
            • 572
            #215
            Finished the the dry fitting for the 9th course yesterday and will be setting it today.........How long before I can remove my inner arch support?
            Respectfully,
            KB
            My build
              I think that you could have removed it about 30 minutes after you completed the arch .
              Some great looking brick work there KB.
              • kanoer54
                • Apr 2013
                • 137
                #217
                after being introduced to this website 6 months ago i have been following a lot of these WFO builds from all over the world. lots of great work.
                bartman,you have some really nice brickwork there. well done. are you running your flue thru your screened cage?
                looking forward to starting my build and hope it is 1/2 as well done as yours and the others.
                jon
                jon
                • kbartman
                  • Feb 2013
                  • 572
                  #218
                  Thanks all for the compliment?s......tuff going thus far......Yes I will extend the chimney thru screen enclosure. 9th course complete
                  Respectfully,
                  KB
                  My build
                  • kbartman
                    • Feb 2013
                    • 572
                    #219
                    jon
                    Jon,
                    Glad to have ya aboard......Thanks for your comments....Looking foward to seeing your build.
                    Respectfully,
                    KB
                    My build
                    • kbartman
                      • Feb 2013
                      • 572
                      #220
                      Arch supports a goner....... Dry fitted the 10th course today............ Modeling clay still working good............. I'm thinking of going back to a full size half brick on the next course............Any suggestions?
                      Respectfully,
                      KB
                      My build
                      • kbartman
                        • Feb 2013
                        • 572
                        #221
                        10th course is complete..........I'm hoping three more courses then plug...??. I can finally see the light at the end of the tunnel picture #3 the heavenly light from above........LOL
                        Respectfully,
                        KB
                        My build
                        • K79
                          • Nov 2012
                          • 391
                          #222
                          Looking real good. Nice joints.
                          Link to my oven build on YouTube:
                          http://www.youtube.com/watch?v=Ujb7lqVcSzQ
                          • kbartman
                            • Feb 2013
                            • 572
                            #223
                            No work on the oven today............First tropical system of the year, tropical storm "Andrea"??. Warning in affect.........High wind and heavy rains and possible tornadoes for my WFO next 24hrs...... hope she can take it..........Pool already overflowing
                            Respectfully,
                            KB
                            My build
                            • Bec1208
                              • Nov 2012
                              • 416
                              #224
                              Steady, though light rain in Tallahassee so far. Hope you ride out the storm without problems. Bruce
                              Link to my build here:
                              http://www.fornobravo.com/forum/f6/3...lly-19181.html
                              Selected pictures of the build.
                              https://picasaweb.google.com/1168565...g&noredirect=1
                              sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
                              • Bec1208
                                • Nov 2012
                                • 416
                                #225
                                Well are you still bailing out the oven or did it stay dry? Curious minds want to know. Bruce
