Re: Randy's dreams do come true oven build
Hi Steve good question I am planning to understand screw the front panel then plunge cut the back layer to make a hole so I can get at the back side to take the screws out. Then I am hoping that the 1/8" Masonite will pull away or break away. Then I pocket hole drilled the rest of the bracing so that can all be removed then. Let me know if you see another problem.
Randy
Randy
