  • #46
    Our goal is not to harp on the issue but to make you oven the best it can be. With all your hard work of planning and design, it will be a great oven. A 5 to 1 pecrete mix is suggested for under the floor and dome since this ratio has enough compression strength for supporting the dome and floor and adequate insulation value. Roughly 4" 5 to 1 pcrete equals 2" CaSi. So a total of 4" CaSi equivalent is a very good insulated floor.
Name:	Vcrete K values.jpg
    • #47
      I have almost everything I need to build the oven purchased and stored in dry basement over winter, I already purchased perlite, "Ceramic fibre blanket 2300°F 1'' 8LB/FT3 (1 Box 47.3sf)", and 5 count of "Ceramic fibre board 2300°F 2'' X 12'' X 36''" . I even have ThermoBond 915 100lbs refractory mortar purchased about a year ago placed in tight closed plastic pail never opened yet. The only thing I haven't got yet is either refractory castable or a steel plate for the doughnut base. so my design requires using ceramic fibre board under insulation not CaSi board
      for weeping holes, I could even cut using my concrete saw shallow channels grid all over the slab; however unfortunately, at this moment, I am still not sure I need to do anything for making a "pooling water" drain from a hole because: I have a 6" thick slab placed mostly on grouted cmu block cores with very little gaps under it and still connected to a bottom slab that is 5.5" thick ... and got lots of fibre on slab. I can't imagine the oven can produce enough moisture to saturate close to 3 tons of concrete between firings . I most likely be a light user of the oven, may be fire it few times a year or so (not good to plan to design it so though). I have a feeling that weeping holes would be more suitable for large open span slabs with wood being stored under the oven that the slab would be bowed in centre creating a gap between the oven base and the slab where it will get filled with no emptiness but moist air. My priority in my oven is to have extremely rigid and stable foundation that will not propagate settlement to oven and water should not get on it. I still have close to a month to research it more and decide , for now just waiting for concrete to cure.
      any help about my insulation stack design and if I should use castable refractory for dome wall support or instead use a 1/4" mild steel sheet one? as I am not using tiles under the dome walls, the ceramic fibre board and perlite if they creep or settle could cause settlement on a half brick and that if combined could cause a dome instability, so wanting to put a very solid doughnut under the dome walls ONLY while hearth can be on its own ...
      • #48
        The problem is that water is conductive, air is not. This leads to moist insulation not working as an insulator. This fact combined with water in a liquid state creating more than 1500 times its volume as steam when heated, means that small amounts of water will negate the insulative quality of the insulation. Every oven owner becomes surprised by just how much is generated and how much difference it makes to the efficient operation of their ovens.
        Any mild steel used in the build particularly if thin, is prone to corrosion from the combination of heat and moisture, always use stainless.
        • #49
          it all depends on the form of water and where the oven is. In Calgary, water is:
          -water=ice
          -water=nightmare in -40C, -20C, 0c
          -water can turn ice from October to May
          -steam water will turn to ice powder in cold weather
          - water= damage as it expands and freezes
          having weeping holes on slab in winter is not very useful because they will certainly get blocked and ice, only way to get them open is if concrete temperature rise above zero for a while which will not happen probably for hours of firing because of insulation and outdoor temperatures and wind .
          A positive thing of living thousands of kilometres away from warm ocean with sun taken vacation for whole winter is outside air is mostly dry so water can fly free when not too cold
          Therefore, protecting oven from downpour is the best thing someone like me can do, moisture build up inside oven will be limited to water content inside oven cooking chamber from food and fuel. The thinking of water coming from air vapour and becoming water pooled inside insulation will not apply much as I think dealing with designing an exist fo water from a confined place will be unworthy knowing the oven got a mouth and a chimney to vent off
          • #50
            Water expansion on freezing is around 9% and in Calgary is certainly something you need to be wary of , but when it turns to steam can expand more than 1500 times which is 150000% and something oven builders need to consider wherever they are. Water will eventually be eliminated by fire, but its exit is far quicker and simpler if an exit path is provided, just like a fire exit in a crowded hall.
            The way you have built your stand will not allow for drilling holes from underneath once the oven is built over it, so plan carefully.
            • #51
              if I lay rebars on top of concrete slab then pour the perlite-cement on them (as shown in above image), after the layer is cured, the rebars can be pulled out leaving a hollow channel in the insulation layer where water can seep out, the channels will meet near the oven mouth area, then concrete saw shallow cut on concrete slab will channel the water further to the front edge of the concrete slab (there is no insulation there, finally a 1/2" hole is drilled at about 10" away from the front edge of the slab allowing any water to weep and drain there. of course, the water channel can be covered with a masonry layer/sheet later to prevent water from back flowing. It might be that half of those channels are needed (like 5 or 3 instead of 9. what do you think? does that work?
              • #52
                This idea should work quite well. Because rebar contains ridges designed to increase grip and reduce pull out I think some plastic conduit wrapped neatly in plastic would be far easier to pull out, but I’m sure you’d work it out. Also spraying with cooking oil helps release anything from concrete work.
                • #53
                  That is something new, will be interested on how this works. Remember, even 5 to1 pcrete seems crumbly until it sets up so don't pull out too soon. Dave brings up a good point on the rebar ridges but maybe the vapor barrier will solve the friction issue of pulling the bars out. What about reversing the direction of the weep hole and rebar then the weep hole is in the back of the oven slab, out of sight out of mind.
                  • #54
                    reason to use front:
                    1) I plan to put my feet in the 12" between slab front edge and the front wall, that will make my feet under the slab while my body flush with the slab edge and then my arms can extend toward oven mouth with more reach of the 12"
                    2) oven mouth will be 12" away from slab front edge that if I stand at slab edge I will be far. reason of leaving the 1ft on front is to allow to rest the pizza on.
                    3) I plan to store wood in the 12" space at the back under the slab, less space is possible in front where my feet will go. should use external wood storage like a shed for long term (may be not to avoid mice).
                    4) the top concrete slab is naturally 1-2 degree sloped forward (front lower than back)so its easier to have the dripping water drips forward than backward avoiding additional back sloping
